Question about Canon FAXPHONE L80 Laser
Canon L80 prints with 1/2" blotches, in a column down the page, where the toner has not been heated and is not "set." Seems that something is on a roller somewhere and is blocking the toner from setting properly on the paper. How can this be cleaned?
Toner wipes off page?
Your Fuser--specifically, the pressure roller is worn out...Not worth the replacement cost on this unit.
Posted on Feb 21, 2009
Why is magenta blotching on left side of printed page?
Nov 05, 2015 | Samsung C460FW Multifunction Printer...
My brother mfc 7440N prints splotches every 3-3.5" on every page printed. This occurred with the previous and new toner cartridges. How to fix?
For crying out loud.
The "blotch" is caused by damage to the drum or to the toner fusing roller.
If the "blotch" is loose toner (in other words you can smear it) then the fuser roller is damaged and that assembly needs to be replaced.
If the "blotch" is fused (in other words you cannot smear it around) then the drum is damaged and that assembly needs to be replaced.
The original MSRP for the Brother MFC-7440n in 2008 was $429 (US) / 213 pounds [FixYa couldn't handle the pound sign!! =8-) ] (UK) / $499 (AU). The present street value is about $199 according to Brother ( ).
A drum unit is $80 (Amazon) or $115 (Staples).
That same $200 could get you a Canon Pixma MX-922 (Canon Inkjet? Yes. But fast. Airprint. 2-sided ADF and copying. Auto-duplexing. CD/DVD disc printing. Frankly, if I didn't already have an Epson 835, I would buy this one. My old Canon 820 still chugs along as beautifully as the day I got it (about a zillion years ago).
For $50 more you can get a top-rated laser, their imageCLASS MF4880dw (though oddly, without Airprint - for Airprint in a Canon laser, you have to step up to the big boy: the imageCLASS MF8580Cdw).
Well. Have fun!
Mar 31, 2013 | Brother MFC-7440N Laser Printer
Toner blotched on printed material When printing
If the line has a 1/8" white margin on either side, clean your glass and mirrors.
If the line is all the way across your page, consult your users manual for cleaning the sawtooth electrode (open the front door and take out your waste tank, there is a green rod on each drum cartridge you can pull and hear a zipping noise) and cleaning the laser lens (there should be a cleaning wand under your waste tank, turn pad side down and insert in the gap underneath your drum cartridge)
Jan 14, 2011 | Sharp MX-3501N All-In-One Printer
How to print a tx report with canon L80 faxphone?
Here is a link to Canon for your FaxPhone L80 Users Guide. Reference page 14-3 to access the menus, page 14-5 for report settings, and 14-6 for TX Settings
Jan 07, 2010 | Canon FAXPHONE L80 Laser
Canon faxphone L80 parts available? paper feed shaft broke in half
The L80 printer guts are very similar to the HP 5L and HP 6L printer (Not well known, but the printing engines on many HP printers are made by Canon). In fact it is almost possible to use a 5L/6L toner cartridge in the L80, but as I recall there was a plastic nub that prevented it from fitting properly. This is probably meant to force the user to buy more expensive Canon toner carts instead of using cheaper generics for the 5L/6L. Try HP PartSurfer and you may be able to locate the part that you need.
Jul 29, 2009 | Canon FAXPHONE L80 Laser
Toner Smearing
It's actually heat and pressure, that 'melts" the toner to the page, and what is happening in your case, is that the pressure roller is worn out, so you're not getting the contact between the heat and pressure rollers necessary to properly adhere the toner. This will require a service tech should you want to spend the money to repair it.
May 24, 2009 | Canon FAXPHONE L80 Laser
Don't know that machine all that well, but it sounds like the laser filter glass may be dirty, or the laser unit. It seldom happens, but did you by any chance blow it out with compressed air?
Anyway, you may try taking out the toner cartridge, and if you tilt the machine upward you should see a sort of 'filter glass" above where the cartridge sits that allows the laser light to pass through from above. try cleaning this with a cloth, and hopefully that will solve your problem.
Mar 09, 2009 | Canon FAXPHONE L80 Laser
Vertical White Line printing down the page
Hello sir; I believe you have running out toner , try put a new one see what's happen.
Feb 03, 2009 | Canon FAXPHONE L80 Laser
Fax confirmation
1. Press Function key
2. Press Data Registration key
3. Press Set key
4. Use (up or down) arrows to select REPORT SETTINGS
5. Press Set key
6. Use arrows to select TX REPORT
7. Press Set key
8. Use arrows to select OUTPUT YES
9. Press Set key
10. At PRINT WITH IMAGE, use arrows to select YES or NO (YES will print the first page of the fax with the report)
11. Press Set key
12. Press Stop/Reset key to exit menu
May 23, 2008 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 confirmation
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Feb 20, 2008 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
65 people viewed this question
old marine
old marine
