Question about HP Compaq Business d530 Small Form Factor PC Desktop
Microsoft patch error micosoft processor update
Update intel pentium d 945 procesor mikrocode patch
You didn't state the O/S.
So I'm going to use Windows XP Home for an example;
HP Support > HP Compaq dc7600 > HP Compaq 7600 Convertible Minitower PC > Download drivers and software > HP Compaq dc7600 Base Model Convertible Minitower PC > Microsoft Windows XP Home Edition >
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1111121&prodTypeId=12454&prodSeriesId=472276&swLang=13&taskId=135&swEnvOID=1098
BIOS > 786D BIOS Family Processor Microcode Update
Current version -> 11.1A / 31Jul/ 2006
Size -> 0.38
Estimated download time -> 1Minute
Previous version -> 1.09A/ 11 Oct 2005
Click on Download at the end.
A small window will come up on the right.
Opening sp33313.exe
Click on Save File.
Another small window will come up on the left. In the wording at the top of the window tells you where the file will download to. You may wish to write it down.
It may have Desktop, or My Documents, or Downloads, in the wording.
Desktop: The file will be on your desktop screen
My Documents:
Click on Start, then My Documents
Downloads:
Click on Start, then My Documents. DOUBLE-click on Downloads
When you see the file name (sp33313) DOUBLE-click right on it
The Installation Wizard will appear. At the bottom of the next 3 small windows, click on Next, Next, and Finish.
If you are not asked to Restart your computer, close all windows, go back to your desktop screen. Restart your computer.
(Start > Turn Off Computer > Restart )
Regards,
joecoolvette
Jul 09, 2012 | Computers & Internet
Display come wiht patch error
Great job replacing the processor, but I'm guessing you put in a different model and the error stems from the OS at hand not knowing how to deal with the minor change. You can probably search the web on some details from the error message, (and your OS) and find a registry or kernel correction to start without reinstalling the OS (and its processor patches.)
Mar 09, 2010 | Compaq Computers & Internet
Error Code: 0x66A
It appears to be a Dot Net framework installation error related to the version or an update patch.
The likely solution that will work is to use add/remove programs to remove dotnet installations or updates (updates first) then reinstall dot net from Microsoft.
Usually this error is due to trying to install a wrong version or having two versions installed.
Oct 24, 2009 | Microsoft Windows XP Home Edition
1801-microcode patch error
Hi according to HP memo see the following answer hope it help:
DESCRIPTION After installing a different system board or processor in systems described in the "Scope," the systems may halt during POST and display an 1801 Microcode Patch Error with a prompt to press the F1 key to continue.
NOTE Pressing the F1 key will allow the system to continue. However, processor performance may not be optimized and the error will repeat each time the system is restarted. HP recommends that the microcode be updated to ensure optimum compatibility and performance.
Sep 09, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
1801 micro code update error
You need to update your Intel processor microcode patch. This can be updated independently of the system BIOS. The latest microcode update for the d530 786B2:
http://h18007.www1.hp.com/support/files/hpcpqdt/us/download/21270.html
If you use this and still see the POST error message, please go into F10 Setup under System Properties and report the detailed description, including the stepping, of the processor in your system.
Jul 03, 2009 | HP Compaq Business d530 Ultra-Slim PC...
ERROR
Download BIOS update form the website for your motherboard.Burn it it cd if you get that type of writable image on site. Or use another processor to make update on this mainboard. Dont forget, NOT ALL CPUs ARE COMPATIBLE WITH ALL MAINBARDS. Check If your processor is supported.
Apr 03, 2009 | Foxconn Computers & Internet
Generic host win32 services problem
Generic Host Process for Win32 Services Error is a broad issue.microsoft has a patch for this issue.You may download the patch KB894391, to fix this issue.
or
Alternatively you can do windows update manually (Note that the above patch solution and the following windows update solution works only on PC/computer running genuine Windows and not pirated versions):
  • Go to the start menu
  • Right click “My computer”
  • Click “properties” then the “automatic updates” tab
  • Choose “turn off automatic updates”
  • Restart your computer
  • Go back to start menu and in all programs go to “windows update” you have to be connected to the internet
  • Manually update windows
  • Turn your automatic updates back on
You can also try the following solutions to fix this error:
Solution 2:
  • Go to Run and type regedit
  • Navigate to HKEY_LOCAL_MACHINE >> SYSTEM >> CurrentControlSet >> Services >> Browser >> Parameter
  • look for the key IsDomainMaster
  • Set its value to False
  • Restart the computer
Jan 22, 2009 | Microsoft Windows XP Media Center Edition...
Downloaded a microsoft patch, system will not restart
1)Go in to safe mode
 2) try to get back your sys. using system restore point.
Dec 18, 2008 | Microsoft Windows XP Professional
HP Compaq Business d530 Small Form Factor PC Desktop Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
