Question about Acer TravelMate 2300 Notebook
Common problems with finger scanners
I am researching common probelms with finger (biometric) scanners and who they are solved .
We are currently having issues with a new Time Clock system regrding the canning of certain individuals and I am hoping you might be able to put a light on some of the issues with fingers not being scanned and how the issues might be resolved
Thanks for your assistance
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Bizhub C224 Color Copier /...
Biometric finger print verification problem in IE8 32Bit
go to control panel
open java
you see java configuration
go to security tab
select use java in brousers
and scrool down secruty bar to medium or low
restart computer and check
Feb 08, 2014 | SecuGen Hamster Plus Fingerprint Scanner
My finger print is unable to obtain authentication or input/output error has occurred am using it to register student for jamb exam
Ade, if u r using your scanner on jamb website. You will need a
- You to provide 16 characters security key. - biometric license and - JAMB Biometrics Capture/uploader software.
* The biometric license gives you authentication while the JAMB Biometrics Capture software allows you to capture thumb-print even when there is no internet connection(offline) and automatically upload them to server when the internet is back.
You can thumb-print as many student as you can (I have seen a client who thumb-printed as many as 2000 in 3days).
We give technical advise and we have several license in stock to give away. While not call us today, if the problem is still persisting. Call 08132829820 or email us on biometricmasters2000-jamb@yahoo.com
Feb 18, 2011 | DigitalPersona U.are.U 4000 Fingerprint...
I bought and install the U are u biometric finger print scanner to be used for JAMB utme examination in Nigeria. when ever i connect to the site www.jamb.org.ng to capture finger print and upload, the site...
Do you have a biometric license, if not, you need one, contact us at biometricmasters2000-jamb@yahoo.com.
Do you provide the 16 characters key ingto the scanner softwares. We want to help you to succeed.
Feb 09, 2011 | DigitalPersona UareU 4500 Fingerprint...
I am trying to register my finger from digital persona but its giving an error report: unable to obtain authentication input/output error has occured.
Dear Big, if u r using your scanner on jamb website. You will need a - You to provide 16 characters security key. - biometric license and - JAMB Biometrics Capture/uploader software. - Your operating System software must be 32bit(XP, Vistat, Win7)
* The biometric license gives you authentication while the JAMB Biometrics Capturesoftware allows you to capture thumb-print even when there is no internet connection(offline) and automatically upload them to server when the internet is back.
Jan 30, 2011 | DigitalPersona U.are.U 4000 Fingerprint...
Unable to obtain authentication input/output error has occurred. Error while loading applet Module is not registered.
Check to see if more than 1 biometric scanner is enabled @ device manager>Disabled all leaving only 1 supported finger print scanner enabled.
This error is most common if you have on-board or integrated biometric Reader...Try this 1st;still got answers if this doesn't work but it's been proved as remedy for this particular error :) Thanks
The Rule is:Help others without charge :)
Jan 10, 2011 | DigitalPersona UareU 4500 Fingerprint...
I site www.jamb.org.ng requires that i use a finger print scanner. I have installed the You are you 4500 fingerprint scanner to my system, it worked previously, until a virus made me to reload the comp....
HTML clipboard 1. This kind of problem happens when you re-formatted your computer
2. You just install your scanner this year
3. You did not have biometric license installed on your computer, this license makes your scanner authenticated over the internet when you are visiting jamb website, if you are in Nigeria. It also comes with Jamb Biometrics Capture Software, .Net Framework, Java Framework and other software that will make your experience very simple after installing.
4. If, you have the license, then you did not supply the 16 digit security code for the scanner.
The way you out, you need BIOMETRIC LICENSE, if you are operating JAMB BUSINESS.
Hope this help you, if you need more clarification you can email me on biometricmasters2000-jamb at yahoo.com or phone me on 08132829820
Dec 28, 2010 | DigitalPersona UareU 4500 Fingerprint...
We have a biometrics gadget in the office to monitor time in and out. My finger prints are so shallow that the machine always fails to recognize my finger print. What do i need to do.
to sign my daily (though a fingerprint machine )attendance I face continuos annoying problem which the fingerprint machine can't identify me in spite of I changed the fingerprint from finger to another but everyday i face this disgusting problem .\r\nwhat can i do?
Aug 31, 2010 | Precise Biometrics 100 AX
SentrySafe DA3930 Biometric Fingerprint Safe Item Number 681814 will not recognize my finger print!!!! I have been trying to get into it on and off for 3 months. Is there a reset code???
contact sentry
biometric scanners DO NOT WORK
prove your ownership
and they may assist you
and
Sep 14, 2008 | Sentry Fireproof Safe
Computers & Internet Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
