Question about Williams 2509612 Ceramic Mid-Size Heater
Pilot lites but goes out when button is released
Has worked fine for 4 years. Just went out one day.
havn't got it to stay lit sense.
Did u change thermocouple?
Posted on Feb 21, 2009
havn't got it to stay lit since.
Posted on Feb 25, 2009
Pilot lite will not stay on when I release the igniter pressure knob REH-18-N wall heater!
IS there gas? YES ok. So if you can get the pilot lit, but when you let up on the button it goes out. Few things to check. On some heaters the manf. install a safety switch to drop the pilot out if its not venting or if its over heating.
Jan 01, 2017 | Heating & Cooling
Why it doesn't stay lit
Replace the gas valve or thermocoupler.
Oct 15, 2013 | Coleman 5040-751 BackHome Open Flame Patio...
Rheem Fury Gardian 40 gal LP water heater pilot will not stay lit
1) Clean air intake (flame arrestor):located under combustion parts and look for broken glass from TRD
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
2) Troubleshoot by type of gas control, and link to AS Smith service manuals
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Add a comment with more information
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Dec 24, 2012 | Water Heaters
Pilot don't stay lit after the gas control knob is release.
The thermocouple is bad and you will have to replace it...
The thermocouple is the thing that sticks up in the flame to sense that the flame is on... if it goes bad the pilot flame will not stay lit when you release the button...
heatman101
Dec 05, 2010 | Williams 3501922 (NG) Gas Compact Heater
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Water heater will not stay lit even after replacing thermal coupl
The pilot must encompass the thermocouple "bulb" in order for the thermocouple to generate enough current to keep the pilot valve on. You must also hold the red button down for a long enough period to get the thermocouple hot. If the pilot is not large enough, it could be due to a clog in the pilot orifice at the pilot itself. Sometimes a couple of passes over the end of it with fine steel wool is all it takes to clear it.
Hope this helps. Feel free to share what you found. Thanks.
Jul 16, 2009 | Kenmore Dryers
ES 160000 Endless Summer Patio heater won't stay lit
Bad thermocouple that senses the heat from the pilot light. This would be evident if you lite the pilot while holding the button down for about 30 seconds. If the pilot goes out as you release the button on the gas valve replace the thermocouple.
Oct 30, 2008 | Heating & Cooling
Williams 2509612 Ceramic Mid-Size Heater Logo
123 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
