Question about Onkyo TX-SR501 Receiver
Onkyo tx-sr501 memory settings loss
Hi fixia,
I have a onkyo tx-sr501E home theatre amplifier and I fase problem with its memory settings. They are lost after power unpluging!
do you have any idea apart from having amplifier power pluged every time?
thanks in advance
smeago1
  • 136 Answers
SOURCE: Blank display on a Onkyo TX-SR501
try to connect the receiver to a tv via the monitor out from the receiver to the tv. you may be able to see the OSD (on screen display of your settings) change the function on that to turn on the front display. alternatively look on your remote to see if you can turn up the light of the front display.
if these don't work possible that the light of the display has blown.
good luck
smeags.
Posted on Dec 31, 2007
  • 4234 Answers
SOURCE: receiver does not power on. standby not on either
The standby light should be on. If it is not, then check the main fuse. WIth the unit unplugged, remmove hte top cover and check the fuse by the line cord. If that is ok, then you will need to check the primary winding on the standby transformer. That transformer has a thermal fuse internally located and that sometimes gets blown due to a power surge. If you do not have the equipment to test this, get a detailed estimate from a local servicer. The standby transformer usually costs arounf $25 or so.
Dan
Posted on Apr 26, 2009
SOURCE: No audio sound from HDMI connection from TV to Onkyo 606 amp.
if you go to the setup menu, hardware setup, hdmi, and turn the audio out: on it should work hope this helps
Posted on Jul 29, 2009
  • 3 Answers
SOURCE: Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Posted on Jun 24, 2010
kerguney
  • 577 Answers
SOURCE: need downloadable users manual for
hi,
you can visit the following web site to download the manual you need..
Take care..
http://www.scribd.com/doc/38031058/Onkyo-Receiver-TX-906-TX-904-User-Guide
Pls remember to rate me afterward..Thanks
Posted on Jun 19, 2011
I have an Onkyo TX-SR501 reciever/home theater amp. The sound works fine in home theater mode, but no sound when FM mode selected, but fine in AM mode. Have checked Antenna.
Hi Anil, please make sure the the receiver is locked into the station. It should read FM Stereo when locked in. Thank you, Onkyo USA
Nov 23, 2016 | Onkyo TX-SR501 Receiver
How to connect av receiver to dvd player and hdtv
You can go to the manual at the link below and follow the directions
Links
Aug 17, 2008 | Onkyo TX-SR501 Receiver
My stand by light flashes on my onkyo tx-sr501
Check output transistors for short, change emitter resistors
Mar 30, 2014 | Onkyo TX-SR501 Receiver
I don't have the manual for this receiver and I would like to hook up my hd tv to it. How do I acquire the user's manual? Thanks, jmp
Use a search engine for "Onkyo TX-SR501 manual"??
Hint: retrevo has it.
You might also hunt for the TV manual as IT is a player in the scenario, too.
Jul 24, 2011 | Onkyo TX-SR501 Receiver
Can you tell the wattage of the onkyo tx 905 not the home theatre model stero only
140 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven from 20 Hz to 20 kHz, with a
maximum total harmonic distortion of 0.05% (FTC)
170 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven at 1 kHz, with a maximum total
harmonic distortion of 0.7% (FTC)
180 watts minimum continuous power per channel, 6 ohm
harmonic distortion of 0.1% (FTC)
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
Loss of audio from onkyo 605
If the settings are correct, then it is just like the 605 I had, its broken. Get one made by someone else if the warranty has expired on it. I suggest Pioneer.
Apr 06, 2009 | Onkyo TX-SR605 Home Theater Receiver 7.1...
The amplifier does not recognize the dolby digital format, I have replaced the DVD player without any result. there is some setting that I need to change? thanks
Be sure you are using the DIGITAL connection to the "amplifier" or "Receiver"? This is the OPTICAL connection or the ORANGE colored coaxial connector, they will be labled digital. Be sure also on the DVD player DOLBY DIGITAL AUDIO is ENABLED. Not on the DVD software startup menu, but the DVD PLAYER unit itself. This can be found in the setup menu under AUDIO OPTIONS. If you have the DVD players manual read section Audio selections.
Jan 31, 2009 | Onkyo TX-SR501 Receiver
Onkyo tx-sr500; power goes out; standby light blinks
Remove all Wires form speakers
Power on
Push Video1 + StandBy /On
appears Clear on display
Dec 22, 2008 | Onkyo TX-SR501 Receiver
good luck
smeags.
Dec 31, 2007 | Onkyo TX-SR501 Receiver
Optical sound
I think what I might do is use an optical splitter: http://www.amazon.com/Digital-Bi-Directional-Optical-Toslink-Splitter/dp/B0002MQGR2, does anyone have any experience with this?
Dec 05, 2007 | Onkyo TX-SR501 Receiver
Onkyo TX-SR501 Receiver Logo
189 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
