Question about Radio Shack Pro-95 Handheld Scanner
Bearcat 50 channel scanner
I've lost manual, and forgot how to program channels in scanner
  • Radio Shack Master
  • 5,568 Answers
Your model number doesn't seem complete so you will have to research it on this page:
Uniden Manuals
If you can find it, the download is probably free.
Posted on Feb 20, 2009
Need antenna
This radio has a standard BNC antenna jack. Radio Shack does now offer an antenna with a BNC connector on the end that you can use with this radio.
Dec 03, 2012 | Uniden Bearcat 855 Xlt 50 Channel Scanning...
My uniden bearcat 50 channel 800mhz stop the police,fire ect.. and only gives me weather.. why? can you help ?
  • You can try pressing "Manual" and then "Scan" or "Band" buttons from the weather setting to get you back to scanning the police, fire,etc.
  • Make sure you don't have a WX (Weather) frequency programmed into on of the regular 50 channels or the scanner will continue to stop every time around as it will pick up the WX frequency.
  • Make sure you have your scanner programmed as well.
Regards, Tony
May 27, 2011 | Uniden BC80XLT Handheld Scanner
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
How to program the frequencies on a uniden bearcat 50 channel 800 mhz radio scanner?
To program the majority of non-trunking Bearcat scanners,\:
- Power the scanner ON
- Press MANUAL to stop scanning
- Enter the channel # to program followed by MANUAL (OR just press MANUAL repeatedly to advance to the desired channel).
- Enter the desired frequency, including the decimal point.
- Press E (ENTER)
If these steps don't work with your scanner, please provide your model number and I'll get back to you with specifics.
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
How to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
Jul 31, 2009 | Uniden BCT8 Base Scanner
How to program my uniden bearcat scanner bc350c
to listen to the programed channels you need to turn the squelch up to to the right and press scan it will scan all the channels and stop on the ones that people are talking on. you can down load the user manual at the bearcat scanner website.
Jan 19, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Lost book to scanner its a uniden bearcat bc145xl 16 channel and dont know how to program it.please help
do you have a button marked "prgm"
if not, then push the manual button until it
gets to the channel you want to program,
then enter the freq ie... 155.xxx and hit
enter, don't forget the decimal point .
http://www.uniden.com/index/manuals_results.cfm?cat=3
heres a link to uniden bearcat manuals , but i don't see yours .
but my instructions will get the job done .
Jan 13, 2009 | Radio Communications
Uniden Bearcat Scanner Model# BC147XLT
The BC147XLT is too old to obtain a manual from Uniden, but here's how you program it:
Turn it on & press 'Manual', then enter the number of the channel you wish to program & press 'Manual' again. Now enter the frequency you want to put in that channel, example 155.550, and press "Enter'. Then press manual to go to the next channel or repeat the first procedure to select a different channel other than the next one. Repeat the programming procedure for each channel.
Sep 26, 2008 | Uniden BC244CLT Base Scanner
How to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
May 31, 2008 | Health & Beauty
Bearcat scanner 210xl program manual
Here Is A Users Manual For The Uniden Bearcat 210XL 18 Channel Programmable Scanner.
Just Follow This Link And Save or Print It Out In .pdf Format.........
I Myself Used My Dell Laserjet And Printed It As (2) two Sided Pages And Have A Nice Looking Manual. It Is A Complete Instruction Manual That Tells You How To Set It Up!
http://www.repeater-builder.com/uniden/pdf/uniden-bearcat-bc210xl-owners-man.pdf
Jan 24, 2008 | Uniden TRUNKTRACKER III
Radio Shack Pro-95 Handheld Scanner Logo
159 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
