After wiring the unit from the breaker panel it kept tripping the breaker. Now there is no power it seems and the breaker does not trip and the motor does not come on.
MichaelUnwire the motor and turn the breaker on.
Is it the correct voltage going to the motor? If perhaps this is a 120v motor and you have just sent 230v to it you have damaged the motor.
Not sure other than that starting point.
Rod
US Parts Center
888-521-6183
SOURCE: rule 1800 pool cover pump trips breaker
It sounds like the pump motor has shorted. Probably time to invest in another one.
SOURCE: Wired my replacement pool pump motor...tripping
A ASSUME THIS IS A NEW MOTOR ? WHAT CAN BE THE PROBLEM IS A BAD BREAKER, YA I KNOW .. BUT THERE CHEAP. PULL IT OUT AND BRING IT TO HOMEE DEPOT AND GET A NEW ONE. YOU MAY NEED TO SET THE MOTOR TO 230 VOLTS.. SO TRY THAT FIRST.. IF ITS A WIDE BREAKER ITS 230 V VOTE 4 ME AND PRIME THAT PUMP AFTER ANY PUMP REPAIRS !! Jay
SOURCE: turn filter on, pump turns on then trips breaker?
NOT A MOTOR TO TAKE LIGHTLY 2 SPEEDS ARE BIG $$$ . TAKE 4-6 . 9/16 BOLTS OUT OF PUMP DISCONNECT POWER (LOOK) WRITE DOWN COLOR OF WIRES AND PLACE THEY GO TAKE PICTURE ! ! AND DO NOT TRY TO TAKE ANYTHING ELSE APART ! SEARCH FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING USE YOU ZIP CODE IN YOUR SEARCH .COULD BE JUST A BAD BREAKER BUT NOT WORTH THE CHANCE..HAVE A PRO LOOK AT IT. BEST OF LUCK .. VOTE IF'N I WAS OF HELP
SOURCE: I have an Emerson 1081 Pool Pump Motor , every
Well, something is wrong. Either the pump or the wiring from the switch to the pump. Pull the pump and take it to a motor shop and have them check it out.
