Question about Hotpoint NBXR463EBWW Electric Dryer
How to remove top on hotpoint 473e dryer , a need to change the drive belt
    Problem Solver:
  • 16 Answers
Very easy. Unplug dryer. Open the door. Remove the two screws that hold the top on. Lift up on the top and pull toward you. Now look from the top down on the left and right side, remove the two screws on each side. You can now pull the front towards you carefully without pulling out the door wires, very simple. Now remove your old belt. Slip your new belt over the drum (see where it fits on drum, it will be worn) and just let it hang. Be careful it is not twisted. Now remove the bottom right side of the panel on the lower back of the dryer (2 screws). With a flashlight make sure you get the belt on the motor and adjustable pulley that moves when you push it towards the motor. This whole process should take about 10 minutes. GE website has pictures if you need it, GE makes Hotpoint!
Posted on Feb 28, 2009
  • 547 Answers
Top should pop off use screw driver to pry apart there are 2 clips on the corner then lid should lift up
Posted on Feb 20, 2009
  • albert getty
    albert getty Feb 20, 2009
    top should pop off use screw driver to pry apart there are 2 clips on the corner then lid should lift up
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
How do I replace the belt on a hotpoint autima auto dryer
Remove the top cover, and front right hand side panel.
This will give you access to the drive belt.
Hope this helps.
Dec 12, 2009 | Hotpoint Dryers
Main drum drive belt has broken. How to open the back or side to be able to replace the belt?
If it is a full size dryer, then you need to remove the top cover\ and right hand side panel, this will give you access to the belt.
If it is a small compact dryer, then you have to remove the rear panel, and then remove the whole cabinet.
Hope this helps you.
Dec 07, 2009 | Hotpoint Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
Hi there I am trying to replace a belt on my old dryer how hard is it
If you have a NVL333EY which you posted under, I'd rate the repair a 4 on a scale of 1 - 10 in difficulty. That Hotpoint model is actually manufactured by Frigidaire / Electrolux and sold through GE as a Hotpoint. (Hey, it's a global economy, right?)
Disconnect power to the dryer. Use a putty knife to push in the seem of the front panel with the dryer top to release the dryer top, allowing it to swing back. You may be able to use a phillips to remove the screws holding the front panel, but a #2 square drive works much better. Slip new
134503600 belt around drum from front. Put front panel back on. Remove 4 screws (again the #2 square drive works best) holding the back access panel at lower left back side to allow you to finish belt installation. Belt grooves touch the drum. The worst part is keeping the spring from falling off when you put the belt tensioning wheel on. After you have the belt installed, give the drum a turn by hand to make sure everything is OK before you close up the top and reconnect power.
Dec 07, 2008 | Hotpoint NVL333EY Electric Dryer
I need the procedures on how to change the drive belt on my Hotpoint VTD00G Tumble dryer. I've opened the top & front covers, placed the belt round the drum but I couldn't stretch the belt over the...
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Apr 06, 2008 | Dryers
Broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Dec 06, 2007 | Dryers
Hotpoint NBXR463EBWW Electric Dryer Logo
179 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
