Ac heat problem
When i put my remutecontroll at heat mode,ac don''t work,indicator for heat on ac display dose not light,in the others mode of remotecontroll ac is working.can any body tell me where is the problem?
  • 400 Answers
Your reverse valve is either not being energised or is bad and needs to be replaced.
Posted on Mar 12, 2009
Lennox gas package unit blower motor will not run inheat mode with fan in the auto mode but will run in all other modes including ac
There is a Bi-metallic klix-on switch in the heat chamber that senses when there is a temperature rise in the fire box. It supplies voltage to the fan relay when in the heat mode. It's function is to delay the fan coming on so you won't get a blast of cold air out the vents until there is enough heat built up in the heat chamber. Not very expensive either. There is a number on the switch that indicated what temperature it turns on. Get an exact replacement! Any appliance repair parts company will have them.
Sep 24, 2014 | Heating & Cooling
Intertherm p5rd036k
Sounds like your tstat could use some attention. The broken bar sounds like a low battery indicator. To verify wether the tstat is working correctly you can try bridging the R and W wires (after the thermostat) to set a call for heat. Be careful when you do this as you could short or blow your circuit board and other sensitive electrical parts. The R terminal is 24v power and when you bridge R and W you send 24v to the circuit board which indicates a call for heat. W is heat Y is cooling. If nothing happens still then you should call a technician as you may have broken parts and will require replacing.
Dec 09, 2013 | Heating & Cooling
Hitachi split ac ace cutout how to go to standby mode
Its very simple to remove that red light glowing on the AC, just switch-off your AC with your remote, but don't turn off the switch that resides with in the plug, remove filters wash gently and dry under shade and place them again in the AC, now keep it without turning-off the switch for 30-60minutes this is called stand by mode. Now take the remote open the panel and press the button that is situated in 4th row and 3rd column. By doing this the red light will be turned off and enjoy your AC.
Apr 17, 2012 | Heating & Cooling
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Jun 20, 2011 | Amana PTH153B50AM Air Conditioner
Hi My General Air conditioning shows red flashing light when I want to put it on Heat. Why please? Thanks Jurah
Hello Jurah! In the heating mode the a/c for the first 3 min work on preheating mode just to prevent cold air vents in the room. The red light flashing indicate that situation.
Feb 27, 2011 | General Electric AZ29E12DAC Air...
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Oct 16, 2009 | Ruud Central System Air Conditioner
"Ch" is displayed on the display
just press the arrow keys up down and hold it for few sec till beep comes..(on ac scree not on remote)... this indicates cleaning of air filters..
If problem still persists, let me know.
Thanks.
Jun 19, 2009 | Samsung AW1203B Air Conditioner
Ac dose not work, but heat works
If the condensor fan is not functioning no latent heat will be removed and no cooling of refrigerant,
Subcooling needs to be completed get an Ac engineer to change the fan unit.
May 20, 2009 | Heating & Cooling
I HAVE A SPLIT ROOM AIR CONDITIONER, OLDER STILL PACKED BUT WITHOUT MANUALS. THE LABEL GIVES MODEL NO: AG0AH09BWOG1 , SEARCHES DON´T GIVE RESULTS. CHEERS
The number may indicate its a 9000 btu ac/heat pump,just by knowing other types of ac Numbering is it 2 pieces IE;
the outdor condensing unit and a wall mounted evap.do you see a refrigerant line set ,are there connection points for refrig lines etc.
dan
Mar 02, 2009 | GE Heating & Cooling
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
