Question about Lexmark Z600 InkJet Printer
I installed the softwar onto my computer. i got windows vista and the printer has worked before but when i tried to print something it just said pending. I need this stuff printed for tomorrow so how can i fix this? i really need help
  • Quickfx PC Repair May 11, 2010
    Your summary of the problem is a bit confusing.
    You have Windows Vista, the printer used to work but now it gets stuck on pending.
    What software did you install and when ?
    President:
  • 846 Answers
Below is the link to your printer driver download. Uninstall all the old drivers and reinstall the latest ones for Vista. That will probably fix your problem, if not post back.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Thanks for choosing Fixya!
Posted on Mar 20, 2009
I was attempting to install my Lexmark8300 printer onto my computer (with Windows Vista) and I get the "Not a valid Win32 Application" message. What changes could be made to my drivers to fix...
Hello, Are you on Vista 32bit or Vista 64bit? Sounds like you either have a corrupt installer or you are trying to install incompatible 32bit software on a 64bit system.
Download the drivers from here (Lexmark links): 32bit 64bit
Regards, Chris
Aug 15, 2011 | Computers & Internet
Scanning with hp psc 950 on Vista
Hi
The problem must be a simple one. It shuld be due to installation of wrong driver. You can please goto HP PSC 950 support page in HP website and download latest driver for both scanner and printer and try it out. I feel like your problem will be resolved.
Thank you.
Sep 08, 2008 | HP PSC 950 All-In-One InkJet Printer
New ASUS PRO50Z laptop with Vista , trying to install new drivers for Canon PIXMA ip4500 printer. Have installed new drivers from Canon website, plugged in printer to USB port and turned on printer....
have you downloaded the right software? for vista. also try to print something from your notepad or wordpad or a website page see if it will print.
Aug 15, 2008 | Computers & Internet
When i install the printer driver on windows vista is not working
there is a problem on working with software in windows vista. .
try to install the windows XP
Jul 25, 2009 | HP LaserJet P2015 Printer
HP PSC 2175xi prints, but won't scan
you most likely require the twain driver that should work over usb - you should be able to download that from the hp website.
Jun 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP OJ 5610 Drivers-? Can not install printer.
In this case, there's no mystery as to the cause of the problem. You will be unable to use this printer with your operating system because there are no existing print drivers that work with 64 bit Vista. Your printer will work with Windows 98, Windows 2000, and Windows XP, but not with Vista at all.
You have only two options...use a different HP printer that will work with Vista, or get a PC that has one of the supported operating systems on it and connect your current printer to that PC.
Sorry. I know this isn't the answer you were looking for, but that's the best I can do until the proper drivers become available.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Installing problems
If you are working with Microsoft Vista, then take your pc or notebook back to the company you bought it that they can reload Vista. It is probably a software problem. With me it installed etc and i can print, but each time that i must plug in the printer usb cable in my notebook, it tries to install it again. Finally goes the reason, Vista software problems.
Jul 11, 2008 | HP Officejet 6310 All-In-One InkJet...
Printer installation
Hi Nibber,
There is no need to install the printer software in Windows Vista.
You have built in drivers for most of the HP printers in Vista.
Just connect the printer and restart the PC.
Make sure that you are in Administrative mode.
You should not be in Guest Account or Limited User Account.
Try to print from Notepad
Press and Hold Windows key + R
You will see a Run box.
In the Run box type notepad and press enter.
This will open Notepad.
Type some lines and click on file
Print
Else try these steps.
Click on start >> Printer and Faxes >> Click on Add a printer >> Next >> Select Local printer and click on next >> Find printer in the directory >> Next >> Find printer Now >> Select your printer and click on Next >> Next >> finish
Then try printing
Mar 21, 2008 | Office Equipment & Supplies
Couldn't install lexmark 8300 printer software on my window vista driver computer
Follow this link to the official Lexmark website and download the driver.
If you can't follow that link, go to www.lexmark.com. On the top menu, there is a link called "Drivers and Downloads". Click it and select your series, then your OS system, and there you go.
The drivers for Vista are finally updated.
I had the same problem for about a year... now it works fine.
-Ciao!
-Wizkid
Jan 11, 2008 | Microsoft Windows Vista Ultimate Edition
HP LaserJet 3055
i've upgraded my vista printer drivers and all and it still doesn't work ont he same model. i used to run this printer on a XP but working on seperate computer can be too crumblesome. since it's a plug and play on vista with this printer.. my solution is go to windows photo gallery. under the FILE - hit import scanner / camera. - it will auto read ur scan feature. but before that. just make sure u install a scanner onto ur windows . by going to control panels and set up scanner. - connect printer to computer first when u do that. it will rauto read ur printer. the drivers just owuldn't work but the windos software helps to elimiinate the problem.
Oct 19, 2007 | HP LaserJet 3055 All-In-One Printer
Lexmark Z600 InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
