Question about Sherwood RX-4105 Receiver
My turntable works on old reciever and not new one
I hooked my turntable up to the reciever on AUX. I have no where to hook the ground wire.I tried to use AM/FM outlets and even the bolts on the cover.I get nothing? I tried using CD,VCR,TAPE,and AUX please help!
    New Friend:
    Problem Solver:
  • 9 Answers
You need a turntable with a pre-amp since most new receivers no longer support non amplified turntables. I have the same problem which is why I'd like to fix my Pioneer SX-780 vintage 1978+/-.,
Posted on Dec 18, 2012
    Brigadier General:
  • 8,546 Answers
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Posted on Apr 06, 2009
I just got a RCA STAV-3990 Stereo/Audio Receiver given to me. I see I can hook up my turntable into the AUX inputs in the back, but where do I put the grounding wire for the record player? My old stereo...
Use one of the screws that hold the receiver's case. Also, if you haven't already tried to use the turntable, make sure that the receiver's volume is turned way down, typically phono inputs are a lot more attenuated than aux inputs are. You may damage your speakers and or your ears!
Oct 07, 2013 | Audio Players & Recorders
How do I hook up a turn table to a reciever
The wire is your ground, look on the back of the receiver you should see a groung screw, usually silver in colour. Attach the wire to the screw and hand tight.
Apr 09, 2012 | Audio Players & Recorders
I have a garrard turntable and I'm trying to hook
Connect the turntable wires into the recievers phono input and you should be good to go
May 16, 2011 | Technics SA-EX110 Receiver
Hooked it up but sound is very low. Has a ground
Didi you try to change the middle. that was what was wrong with mine
Jan 13, 2010 | Audio Players & Recorders
Insignia stereo reciever inputs stopped working
check a button on the front labeled 'straight' or 'direct'
Nov 02, 2009 | Insignia 200W Stereo Receiver
Can't seem to get any music from the turntable
Do you have the ground wire from the Turntable hooked up to the receivers ground terminal? it's a screw down silver nut and should be next to the Phono input. You are just lacking a ground from the turntable to the receiver. If you don't see a wire from the turntable, look around the chasis of the unit and you will fins it. Hope this helps
Jun 21, 2009 | Yamaha HTR-5740 Receiver
Can a turntable be hooked up to this receiver?
The Aux function is not meant for that purpose.The turntables/Record Players being way too old,now a days the amplifiers do not come with PHONO function that was specially used for playing Records/For turntables. Check if u have a phono function in your amplifier and if not then buy another amplifier with Phono function coz you need a ground wire [that comes out from the turn table] also to be attached to the amplifier and then only you can get a proper sound.
Feb 28, 2009 | Yamaha HTR-5440 Receiver
I just hooked up my old amplifier to my turntable and started playing some vinyl. I'm getting an incredibly annoying static sound through the headphones I'm listening through, and I'm positive it's not the...
Make sure the ground wire from the turntable (they all have one) is grounded to the amp, also the turntable has to be connected to the phono input on the amp. Turntable cant connect to cd or aux. Only phono. Also check to see if there is dust and dirt built up on the needle. clean if needed. most likely a grounding issue
Dec 05, 2008 | Audio Players & Recorders
Hooking up Turntable to Yahama HTR-5660
you have to have a pre amp, or an old reciever with a phono input.
you dont have to use the aux input, the cd or md-cdr inputs will be fine, but you do need that preamp for that reciever
Nov 29, 2008 | Yamaha Audio Players & Recorders
Record player works but no sound from speakers
I've had this happen before, and it is caused by your ground wire not being hooked up. Depending on the type and age of turntable, it will have an additional wire (the ground), that needs to be hooked up to either a screw or some sort of opening similar to your speaker wire hookup. That should take care of the problem. If you don't have a ground wire coming out of your turntable, I don't know how to help, other than figure out how to ground the turntable.
Sep 29, 2007 | Audio Players & Recorders
Sherwood RX-4105 Receiver Logo
255 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
