Question about Canon XL1S Mini DV Digital Camcorder
Canon xl 1s won't power up. Power light flashes, screen lights up then it turns it self off..will keep repeating like this every few seconds but won't stay on help
  • 3 more comments
  • susan spring Feb 20, 2009
    No, it does the same thing when using ac. Video mode works, playback works but when I turn record on,it powers up, flickers and turns itself off..then if I leave it turned on, it keeps trying to restart itself. Have walked thru everything possible on my end with a canon tech. Right now, I am waiting to hear from the repair facility...I was jsut hoping to get a few ideas about what it could be and how much$ to fix it.
    Thanks though for your answer
  • locker39 Apr 08, 2009
    It works in VCR mode, but when you switch to camera mode, it will act like it is powering up, and then shut back down.  PLEASE let me know if there is an easy answer before I send off to Canon.
  • JoyStar Apr 20, 2009
    We have the exact same problem with our XL1S . . . let us know what you find out and we'll let you know if we figure it out.
    Thanx!
    JoyStar
  • ssterrett May 01, 2009
    I have the exact same problem trying to power up in camera mode but then shuting itself off and just keeps doing that no matter the power source. and the VCR mode it works fine.
  • CrAzY H May 07, 2009
    I have the same basic problem. Although my power light doesn't flash. It tries to power up for about 10 seconds or so, the view finder remains blank, and it shuts itself off no matter what I use as a power source.
    I suspect that it is failing one of its system checks during boot up in camera mode. It works perfectly in video playback mode.
  • 3 Answers
Just fixed this problem. It is one of the three main fuses that have blown out. This is not supposed to be consumer accessible or fixable, but I did it.
Open up the camera case using the 5 allen head screws disconnect the top ribbon cable going to the playback buttons on the handle. on the main board (behind the tape deck) are 3 tiny square black fuses The top fuse FU3201 is the VTR The middle fuse FU3200 is the Motor The bottom fuse FU3202 is the Camera/Lense
The bottom fuse was my culprit. I found a tiny piece of copper and bent it into a U shape and slipped it over the fuse so that it touched the metal terminals on both sides and bypassed the fuse. This fixed the problem.
Haven't used the camera extensively since, but shoot about 10 hrs a week with 2 xl1's and will post if anything happens.
Here is a diagram from the Canon XL1 Service Manual: http://www.coycypert.net/files/xl1.png
Here is the service manual download link: http://www.coycypert.net/files/CANON%20DM-XL1.pdf
Posted on Jul 01, 2011
  • john smith Dec 13, 2011
    did anything end up happening?
    Problem Solver:
  • 5 Answers
Read the manual again ? There should be something about that...
Battery is exsausted?
Posted on Feb 20, 2009
I have the same problem but the fuses (7 in this case) are fine :' anyone have an idea? maybe a capacitor? but which? oh god..
Posted on Feb 06, 2015
Hp pavilion dv4 black screen
have some experience as a technician, able to replace the keyboard and palm rest of your laptop.
if it is not able to look for someone who will be able to do
Jan 27, 2014 | Computers & Internet
DSI XL won't power on, but orange charge light is solid (doesn't blink) when charging.
dsi xl getting wrong voltage at plug that goes to the battery. I have 5.78 from charger at battery connections I have 5.78,3.87,0.45,1.98 it bounces all over any ideas?
Jan 25, 2013 | Nintendo DSi XL Console
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
I have a Mitsubishi Model WS-65511 the green light on the front was flahing (would not stop) I replaced the 7 Capacitors as was suggested. The light flashed for a while then stopped and turned green
I think I advised you before (on this page you will find a "make a comment button" which allows follow up questions and answers without posting another question.
Green power light now comes on and goes out in few seconds:
On front of set (not the remote) press and hold when that happens both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit code like 2 blinks, 2 blinks, pause and repeat that several times---this is an error code---let me know what code you find.
Note: if you have unplugged the set it clears the error codes and you have to plug back and try to turn set on--let it fail and repeat the self check.
SD TECH
Apr 22, 2012 | Mitsubishi WS-65511 65" Rear Projection...
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Lamp light flashing on toshiba 50" projection tv
TV tries to come on - yellow light next to power light flashes but then it turn itslef off.........It tries agin after few sceonds and sequence repeats. I can hear the sound but no video
Dec 29, 2008 | Televison & Video
Canon XL1S Mini DV Digital Camcorder Logo
902 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
