Install memory not showing total only half
Aopen mother board model s661fxm-7us, specifications for the board show a maximum of 2gb. I intalled 1gb x2 = 2gb and bios boot and system information is only showing 1gb installed.
I installed one 512 and one 1gb and it registured the correct total.
BIOS ver = Phoenix ltd 6.0 pg
I have read that some mother boards/bios do not show the total amount installed but said it is being used?
  • 3 more comments
  • zuluvector1 Feb 21, 2009
    Thanks for the response Ekse'
    Yes' all specs on mem speed was checked and double checked along with the CL, voltage, DDR all the usual stuff. Memory purchased> Kingston pc3200 cl3 2.6v kvr400x64c3ak2/2g.
    Here's what I did to check mem banks and modules.
    Installed one mem module in first mem bank and then using the same module knowing it was good, installed in the second mem bank; I repeated this action with the second mem module and all tested good. I installed one 1gb and one 512mb and bios and system info read true numbers 1.5gb.
    Checked the bios and no settings available to set bank one or two to enable or disable ecc or any other settings for memory read except to shadow bios and video. K that's my story and I'm sticking to it "lol". I will keep looking to see if there is anything I might have over looked.
    Thanks again Guru'
  • zuluvector1 Feb 23, 2009
    zulu here'
    I suspect that the bios has defaulted to an answer when the mem read is Out of Range at boot. If that is the case then the system can only be using half of what is installed. (I think just answered my own post)
    My concern is that the system is not using the amount installed; if that is the case then I have provided a disservice to my client. If anyone knows of any freeware or software (that won't break the bank) that can bypass the bios and give an accurate read to see how the system is using the mem modules installed, please post.
    My thoughts' if you are going to buy a new MB, make sure the manufacture will guaranty the max mem displayed on the spec sheet will load. I have installed the max on newer machines (4GB) and all was well. I do not believe updating the systems bios (if one is even available) will give me a better answer then what’s been given because the board’s bios (according to the manufacture) will take up to 2GB.
  • zuluvector1 Feb 24, 2009
    Thanks for the tool tip ProsunPal and the additional info.
    The following is the link to the MB manufacture followed by the model and the mem installed.
  • zuluvector1 Feb 25, 2009
    Yep' mem shows that bank 1 & 2 are showing 1gb each installed. That works for me. Thank you again ProsunPal for the cool-tool tip.
  • Thomas F. Schneider May 11, 2010
    Some mother board, and this will be listed in the manual , have a limit to how many pieced Total (electronic chips) are allowed . Does *********** board have this limit?
  • 13,433 Answers
it should show in the bios as 2048.
looking at the details of the motherboard
Memory Type install memory not showing total only half - dtrquestion.gif DDR SDRAM Number of Memory Slots 2 x DIMMs Supported RAM speeds 400 MHz
Got the right speed ram etc?
Posted on Feb 20, 2009
  • Ekse Feb 21, 2009
    When I was looking at the specs, the number 19xx came up, as if it wouldn't support full 2GB. That is odd.
    1GB modules should be supported.
  • 60 Answers
Use the freeware CPUz. It will give you the actual amount of RAM or everything you installed on your system. If it failed it is the limitation of your motherboard. But don't worry physically your system will use 2GB RAM. Be sure about that. So don't worry.
Posted on Feb 23, 2009
    Problem Solver:
  • 18 Answers
Maybe you are not using the right speed of ram for your computer.
a place to figure this at is you will download a very little file that will scan your computer and it will tell you exactly what you have for ram and what type and speeds that are compatible with you pc
I have inserted a 1 GB mamory modual and the system is not reconizing the additional memory. Are there jumpers or switches that need to be reset?
No jumpers or switches need to set. If your going to upgrade/change your memory, just make sure that the memory your're going to insert are compatible with your motherboard. Check the system bus of your memory slots if what are the maximum system bus can support of that motherboard. Like example; DDR PC266 to PC400 or PC400 to PC800, make sure that you are not exced the maximum requirements of the memory for your motherboard it is because they cannot recognize your memory.
Jun 03, 2010 | AOpen s661FXm-7US (918EM10S6G) Motherboard
What is the wireing guide for the A Open s661FXm-7US mother board wireing set up ?
Hi markmincel,
It wasn't easy but you can find the operating manual for this board HERE. Go to the bottom of the page and enter the secret code.
Good Luck,
Nov 19, 2009 | AOpen s661FXm-7US (918EM10S6G) Motherboard
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Whatis the maximum memory the medion rim2520 pc
Standard Memory : 512MB or 1GB Maximum Memory : 2GB ( 2 x 1GB) Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM
Oct 08, 2009 | Computers & Internet
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Start up loop
rest your bios settings put away your vcmos for 15 minutes also u can rest your bios with jumper settimgs near ly the cmos cell set it in 2-3 positon then start the computer then again set in its original position.
Nov 10, 2008 | AOpen s661FXm-7US (918EM10S6G) Motherboard
No sound
i have the same problem u just check out ur device manager what it shows whether what is the status of ur hd dudio if it is working or not if not enable enable it chekc ur bios setup also and all fail then format again and reinstall ur operating sysm hope u get rid off ur problem
Nov 21, 2007 | AOpen s661FXm-7US (918EM10S6G) Motherboard
Computers & Internet Logo
304 people viewed this question
David Payne
David Payne
