Question about Anvil TSA7012 Indoor Grill
A place to purchase parts for Anvil grill TSAQ 7012
    New Friend:
  • 20 Answers
PARTSTOWN.COM or GCS (ECOLAB) are who I use. Make sure you have the MODEL NUMBER and then the wattage and voltage IF you are unsure, then look up the picture on GOOGLE and match up your unit. All the best! Jon
Posted on Jan 23, 2014
Try Selco .com  Just be sure to know the part number
Posted on Apr 18, 2009
Replacement anvil for Loppers
We are not affiliated to Lidl in any way.
Take the loppers into your store with your receipt and if under warranty, they will action a replacement.
Jun 16, 2017 | Vacuums
Im trying to find a new regulator for my infarasonic portable.
HI,
Well the parts for your model have been discontinued.
You can try Sears Parts.
Aug 30, 2008 | Infra Sonic Portable Infrared IR700RL...
I need new grates and heat deflector?
If you want to purchase the parts online this it the best place to shop. They have a large selection of Thermos grill parts.
http://www.clagrills.com/grillparts/thermos/thermos-grill-parts-home.htm
Mar 30, 2011 | Thermos 6000 Traditional Grill
Where can i find electric heating element for my grill(Anvil FTA 8036)
You can get it at PARTSTOWN.COM or you can call GCS (Eco Lab) and they carry is as well -- PART NUMBER for the element is: XFTA0008 (To clarify this is for a ANVIL 36" Griddle with a MODEL NUMBER of FTA8036 230 Volts and 8400 watts.They sell for about 136.00 retail or if you have an account usually about 105.00 Hope this helps,
Jon
Jan 17, 2011 | Anvil FTA8036 Indoor Grill
My anvil electric grill not warm
Could be a couple of things. First check to make sure you have power. Then after checking that open up the bottom with the power unplugged and check the heating element with a OHM meter. Don't know about a OHM meter or Multimeter is, then go on google or YOUTUBE and learn how to use one and if you don't own one, borrow one -- WHile in the OHM meter range check by putting each of the wire leads to each of the heating element ends, IF it registers O.OO, then the problem is NOT the heating element, but could be the thermostatic KNOB CONTROL. IF it is knob thermostat, just order a new one and VOILA! You're back in business!~ Hope that helps,
Jon
Jan 11, 2011 | Anvil TSA7012 Indoor Grill
I need a spring for the press...the other one broke
Go to PARTSTOWN.COM and I saw the spring there - Just enter the MODEL number and it pulls right up - only 7.00 -- Order it and you're good.
Hope that helps,
JOn
Oct 12, 2010 | Anvil TSA7012 Indoor Grill
Hello I am replacing the thermostat in a grill and want to know the order of the wiring. (lost the sequence.)
Should be 2 black and 2 white wires -- each of these wires should be connected to the 2 connections going into the Thermostatic Control Knob. Hope that helps -- IF you still are unsure, then CONTACT ANVIL or VOLLRATH and they will email this to you.
Hope that helps,
Jon
Feb 11, 2010 | Anvil TSA7012 Indoor Grill
New ram for quinny buzz
Be sure it is the gas ram and not the cast aluminium anvil which the gas ram pushes against. The symtoms are similar
This 'L' shaped casting snapped in half on our Quinny Buzz and I managed to repair it by taking the whole centre hinge apart, drilling out the pin which holds one half of the aluminium anvil in place and removing this striaght piece of the anvil.
To repair I first glued the two parts together with araldite then held them in the vice whilst drilling through both pieces to a depth of about an inch with a 4mm tapping size drill. Then seperate the two parts, tap the shank out 4mm and drill the right angled bit 4mm clearance. Reconnect the two parts using a 4mm steel screw and some 'locktight'. Replace the anvil in its slot and replace the holding pin securing with araldite.
Reassemble the whole shooting match and it works ( well ours did....and still does!)
This seems to be a common problem but I could not find any spares. Also the holding pin for the anvil is not made to come out hence having to drill it out. So I doubt if any spares are available anyway.
Not easy and you need a few engineering tools to do the job. But much cheaper than a new frame assembly.
Jan 08, 2009 | Quinny Buzz Jogger
Anvil TSA7012
Go to PARTSTOWN.COm and put in the Model number the spring is 7.00.
hope that helps,
Jon
Feb 25, 2008 | Anvil TSA7012 Indoor Grill
Anvil TSA7012 Indoor Grill Logo
432 people viewed this question
Top Anvil Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Anvil Kitchen Appliances - Other Expert? Answer questions, earn points and help others
