Question about Navarre Quickverse Mac Bible Study 2007 White Box for Mac
Get started with quickverse white box
I've just installed quickverse white box in mac and it starts, shows me the books in the library but I don't seem to be able to open the NIV, for example. How do you open the different books in the package?
Go to quickverse.com download white box 2.02 upgrade.
Posted on Mar 31, 2009
Quickverse library
Noticed in the install.log the file ILI.exe was originally loaded during install, but not on my computer. Looked on another computer I had and the file was there. It normally resides in C:\Windows\System32 but will work if you put it in the Qvlib folder or where ever you have Quickverse Library.
I also needed another fix in the registry. I did a search on qvlib which is my folder name where Quickverse Library resides. In
one instance the data pointed to a wrong location so I corrected it and got my Quickverse Library working again.
How the registry got changed is anyones guess, but it wasn't changed by me. Hope this helps some who obviously have the same problem. It really is a great piece of software that I have been using for years. Best
Feb 19, 2012 | Parsons QuickVerse 7 Essentials (fe11044)...
I downloaded adobe digital editions. They ask for an id and password which I don't have. When I click on the register it sends me to this page. How do I register?
Mac OS solutions Uninstall previous versions of Digital Editions for Mac OS
You must have administrator privileges to complete these steps.
  1. From your user directory, locate /Library/Preferences/Macromedia/Flash Player/www.macromedia.com/bin/open.
  2. Drag the digitaleditions1x5 folder to the Trash, and empty the Trash.
Manually install Adobe Digital Editions for Mac OS
  1. Finish installing or uninstalling any other applications.
  2. Uninstall any earlier versions of Adobe Digital Editions.
  3. Download the installer package for your Mac OS X machine:
  1. Click Open in the File Download screen to start the installation.
    Note: If your connection times out, click Save, instead of Open, to save the installer package to your desktop.
  2. If necessary, unzip the .zip file. If you're using Safari as your browser, or if Firefox is set up to unzip files, the file unzips automatically.
  3. Double-click the .pkg file to start the installer, and follow the onscreen instructions.
Note: If your connection times out, save the installer package to your desktop. (Click the link for your Mac OS X machine, and then click Save.) Double-click the file to start the installation.
Dec 11, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mac book starts with blue screen startup disk full
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
Apr 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mac book only shows apple logo when turned on
This could be an issue where you may have a few Startup items in your StartupItems folder in your System Library which may be affecting your Macbook's startup.
So I recommend you boot your Mac into Safe Mode to see if you can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while.
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Let me know if this helps!
Regards,
-Mactechtrainer
Jan 28, 2010 | Apple MacBook Pro Laptop Computer with...
I have used Quickverse VErsion 7 Deluxe for years on previous laptops using Windows 98 and Windows XP. However, I have installed it on my new laptop using Vista 32 bit and if I right click on the desk
From their website
Question 1:
Can QuickVerse 2007 run on Windows Vista?
Answer: Configure QuickVerse 2007 for Microsoft Vista Compatibility Mode
  1. Download and install the latest Maintenance Release
    Browse to the Program Files folder for QuickVerse 2007
  2. Configure Compatibility Mode for these 2 files:
    C:\Program Files\QuickVerse 2007\qv11.exe
    C:\Program Files\QuickVerse 2007\QVBookManager.exe
  3. Right-click each file listed above and select Properties on the Menu
  4. Click on the Compatibility tab and make the following selections for both files listed above:
http://www.quickverse.com/Shopfiles/Faq.asp?ID=QV2007WIN
Apr 23, 2009 | Computers & Internet
Could not get it working w/ my mac, I am using OSX 10.5.5
There is a vix which I just did for my 10.5.6 but some things still trouble. If you click on a strong's number it won't automatically link to the dictionary. I use right button, then load.
Go to
http://www.quickverse.com/blastcontent/html/QVMAC_MR202.html
Dec 03, 2008 | Navarre Quickverse Mac Bible Study 2007...
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
Quick verse 7
Default Drive
Jul 11, 2008 | Parsons QuickVerse 7 Essentials (fe11044)...
Loading problem
Having problems installing QuickVerse 2006 MacAuthur Commentary Library, Vol.1 & R. C. Sproul Library, Vol. 1?
CD will go through the inital setup, and once it starts its installation process, it stops installing at 5%. Is there a solution in correcting this problem?
Sep 27, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Sep 06, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
Navarre Quickverse Mac Bible Study 2007 White Box for Mac  Logo
370 people viewed this question
Top Navarre Computers & Internet Experts
Tony
Anwarul Haque
Anwarul Haque
Owen Barnes
Are you a Navarre Computer and Internet Expert? Answer questions, earn points and help others
