Question about Dell XPS One Refurbished Multimedia Center PC - Intel Core 2 Duo E4500 2.2GHz, 2GB DDR2, 250GB SAT PC Desktop
Can't view high definition TV on XPS one
XPS one is advertised as an HDTV butI can't get a high def image. Any suggestions?
  • Jkwoner May 11, 2010
    What do you mean you can't view high definition on XPS one? XPS One is a computer...
    You can't compare an HDTV with a HD computer LCD screen.
    If you right click on the desktop, go to properties, and click on settings, TRY TO move the resolution settings all the way left. So that you would have less pixels. THEN you would see the difference between HD and no HD :)
  • RescueTechLA
    RescueTechLA May 11, 2010
    I've always wondered the same thing myself. I've got a laptop with an "HD" screen but I've never noticed any major difference between that screen and my normal lcd.
  • 29 Answers
Your video resolution will be higher than the resolution supporte by your screen...make sure that the resolution of the video should be lesser than your screen resolution.
Posted on Feb 25, 2009
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
I have an Apex digital 32" LCD TV Model LD 3249 and Serial #36056009262 Is this a high definition TV
Yes. 720p High-Def capable.
Remember you have to have a High-Def signal source to actually view High-Definition video. This means local broadcast TV in HD or digital cable TV with HD service and a HD channel or satellite or a Bluray Disc.
Mar 15, 2011 | Televison & Video
I have a 50" hitachi rear projection tv, do i need
rozmyers,
You do not need a high def receiver, your unit has an ATSC tuner which is the same thing. You do need to hook it up to a high definition signal. You mentioned that you have satellite. Call your supplier and order the high definition channels if you do not already have them on the downlink. They should be able to tell you if you have them or not. They should also be able to tell you which channels they are (normally the higher ones). Once you have a high definition feed you will have the best picture you are going to get with todays technology.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Jan 09, 2011 | Hitachi 57S715 57" Rear Projection HDTV
Model LG52LG70 has a problem when switching from High Definition channels to non-high definition channels, and vice a versa. The tv simply shuts off, pauses for 10 seconds and then turns on. Time warner...
Any high def TV will momentarily go blank when changing from High Def to normal mode. Ten seconds is an abnormally long time for that to take place. If you still have a warranty on the TV I suggest you take it in to have it serviced. Otherwise you will have to pay to have this item checked out. There are a number of issues that might be causing the problem so it will be necessary to have a technician check it out.
Feb 18, 2010 | LG 52LG70 52 in. LCD HDTV
I have my polaroid hooked up with an hdmi cable
Thats because your TV is not high definition and cannot process the high def signal. serial hook up does not give a highh def signal.
Nov 09, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
HDTV Reception
Yes , If  a  high definition device is connected to the tv then you can watch high deff tv.
Dec 21, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
Nov 17, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Display delay
This is unlikely Verizon's problem.
Does the delay occur with non-TV sources like DVD player or video games?
If so, that's the LG firmware.
Aug 17, 2008 | LG 42LC2D 42 in. LCD HDTV
How can I tell if my TV has high definition??
If it is high def it will probably have "HDTV" printed on it somewhere. It will have some type of HDMI or DVI inputs. If it's not high def there is nothing that can convert it.
Jul 25, 2008 | Toshiba 32D46 32" TV
Dell XPS One Refurbished Multimedia Center PC - Intel Core 2 Duo E4500 2.2GHz, 2GB DDR2, 250GB SAT  PC Desktop Logo
53 people viewed this question
Alun Cox
