Question about Homelite Mighty Lite Lawn Trimmer
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
    New Friend:
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Posted on Jan 30, 2012
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Toro s-620 fuel primer button broke
any primer bulb will work if you install it between gas tank and carb in the fuel line
Jan 06, 2015 | Toro Garden
Snapper snowblower
The primer bulb is bad. This is letting air into the fuel system, keeping the unit from making maximum power. Replace the primer bulb.
Jan 22, 2014 | Garden
Snowblower carburetor primer not pushing any fuel
Did you replace the fuel lines as well?; the rule of thumb is, when changing out the fuel lines- you should replace the primer bulb since they are a barometer of each others condition and wear.
If you did not remove the primer bulb from the carburetor when you were cleaning the component parts (and predicated that the primer bulb is mounted on the carburetor, as opposed to being mounted remotely from it)- the solvents used to clean the carburetor could have broken down the plastic or rubber material that makes up the primer bulb- hence suction leaks or complete failure.
If you did remove the bulb assembly, make sure you snugged everything up and there's a tight seal. I would still replace it anyway- they're inexpensive.
BTW, you mentioned you are using "fresh high grade fuel"- are you using premium grade gas? If so, save your money and use an 87 regular octane gas.
What you should be concerned with is- the use of ethanol. In many mid-western states, gasoline is blended with 10-15% ethanol- which can absorb water from the atmosphere and cause corrosion in the fuel system.
The money you save from buying regular unleaded could be used to buy a fuel stabilizer, which I highly recommend you use. Gas is only good for about 30 days and then the volatile compounds in it begin to evaporate- leaving brown gummy deposits that will eventually harden like varnish- which can plug up the fuel lines and carburetor.
Please let me know how you make out. Best wishes on your project.
Dec 06, 2013 | Tecumseh Snowblower Snow Blower Starter...
Carburetor change
Primer bulbs pull fuel from the carb, into the bulb and dumps it back to the tank, if you have re connected the hoses to the primer the wrong way around it will try to force fuel into the carb and make it flood.
Jun 01, 2013 | Poulan Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Homelite Mighty Lite Lawn Trimmer  Logo
639 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
