Question about Microsoft Windows XP Professional
System formating i am from hyderabad can we do the complete system format number of times in a week
  • kaberi Feb 21, 2009
    how doing formating in windows xp
  • 42 Answers
If I understand correctly ... you need to format a hard disc partition.
to do that, yo open My Computer, right-click on the partition and select Format. you'll get a small window. You can chose Quick Format, though I don't really recomend it. to start, click the button begin/start/format ... something like that.
Formating erases all data on the partition! be sure to copy everything you want to keep on another partition or CD.
Furthermore, you can not format the partition with the currently runnign operating system on it. for that, you need to do things a bit differently. Post if you'd like that info, too.
Posted on Feb 22, 2009
Give me xp formating system please
Posted on Mar 20, 2009
Transcend usb 4 GB not format
Put your USB drive in your computer and open My Computer. Right-click the USB drive, and then select "Format" from the menu. I would select FAT32 for "File System" and set the "Volume label" to something you like (it'll be the name of the USB drive; enter up to 11 characters (letters and numbers without spaces). You may optionally use "Quick Format" or uncheck it to do a full format. After entering that information, click "Start" and the drive will be formatted. You'll the progress bar advance as it formats. When formatting is complete, you will be prompted.
Feb 03, 2014 | Transcend Electronics - Others
Format local disk d
Formatting any drive will erase your data completely, so take the backup of your drive data and store it other than this drive and then you can format your drive by right click and then choose the option format.
You can also try to defragment your d drive by right click - properties - tools - defragment now, to get some space.
Or you can delete the unnecessary files from your drive or transfer it to the other drive.
Apr 22, 2013 | Lenovo G480 Laptop Computer - 26882LU -...
How do I change the email received day/time format to time/day/month/year format on MS OutLook
Hi George,
You just need to set the correct time zone from Control Panel.
For XP: Just double click the time from your system tray, click on Timezone tab then choose your timezone from the drop down menu then click OK.
For Vista/7: Click on the time from system tray, click on "Change date and time settings". A window will pop up, click on "Change time zone" button, choose your timezone then click OK.
Hope this helps.
Charvin
Nov 21, 2012 | Microsoft Office Outlook 2007: Windows
Format hard drive
Hi
To "format C" means to format the the C drive, or the primary partition that Windows or your other operating system is installed on. When you format C, you erase the operating system and other information on the C drive.
However, it's not a straightforward process to format C. You can't format the C drive like you can format another drive in Windows because you're within Windows when you perform the format. To format C from within Windows would be like lifting a chair in the air while sitting on it - you can't do it.
The solution is to format C from outside of Windows, meaning you need a way to format a drive from somewhere other than your Windows installation. The easiest way to do this is to boot to an operating system (with formatting abilities) from a CD/DVD/BD drive, flash drive, or floppy drive.
This might all sound very complicated but it's actually quite easy to format C. Below are 5 completely free ways to format your C drive:
Note: If you're trying to format your C drive because you want to replace or reinstall Windows, you do not need to format C ahead of time. Formatting is done automatically during the Windows installation. Skip this article entirely and instead see How To Clean Install Windows.
Important: Formatting your C drive does not permanently erase the data on the drive. If you want to completely erase the information on the C drive, see Option 5 below, Wipe the Drive Clean With Data Destruction Software.
1. Format C From a Windows Setup Disc
The easiest way to format C is by completing part of a Windows installation. It's not easiest as far as number of steps goes, but since most of us have a Windows Setup DVD lying around, we have easy access to a means to format drives outside of Windows.
Important: You can only format C this way using a Windows 7 Setup disc or a Windows Vista Setup disc.
However, it doesn't at all matter what Windows operating system is on your C drive, including Windows XP. The only requirement is the disc you use to format C - either a Windows 7 or a Windows Vista Setup DVD. Feel free to borrow a friend's disc if you'd like to try this method but you only have Windows XP... or some other operating system.
2. Format C From a System Repair Disc
If you don't have access to a Windows Setup DVD, but you do still have access to a working copy of Windows 7, you can create a System Repair Disc and then boot to that disc and format C from there.
You can only format C using a System Repair Disc if you have access to Windows 7 to create the System Repair Disc. If you don't have access to Windows 7, find someone who does and create the repair disc from their computer.
Note: A System Repair Disc created from Windows 7 can format a C drive that has any Windows operating system on it, including Windows XP or Windows Vista.
3. Format C From Recovery Console
If you have a Windows XP Setup CD, you can format C from the Recovery Console.
The biggest caveat here is that you must also have Windows XP installed on your C drive. However, if you don't have access to Windows 7 or Windows Vista, this option may be your best to format C.
This Recovery Console method to format C also applies to Windows 2000. Recovery Console does not exist in Windows Vista or later, nor does it exist in Windows ME, Windows 98, or earlier.
Dec 14, 2011 | Samsung R580JBB2 Notebook
I am trying to format sony vaio pcg-c1mrx in command prompt but i dont know what the command to enter. please help me how to do this. thanks!
try these
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B ' /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B ' /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B ' /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B ' /S] [/C]
here are the explanations
/V[:label]
Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C
Tests clusters that are currently marked "bad."
hope this helps.let me know
Dec 31, 2010 | Sony VAIO PCG-C1MRX PC Notebook
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Computers & Internet
How to format my nokia 6300
you must press the call sign, asterisk sign, the number 3 and the on/off. be sure that this signs are press at the same time. don't remove your fingers in the signs of call, asterisk and number 3 until formatting is complete.
Aug 11, 2009 | Nokia 6300 Cell Phone
About formatting of nokia 7610
Lets try........
*#7370#
Jan 18, 2009 | Nokia 7610
DVD-R format not playing
most likely it does not support this video format..have u checked the manual for the video formats it plays?if u can tell me the complete model number can find that out for u..regards..
Nov 07, 2008 | Panasonic Home Theater System System
I do not know how to use my product recovery disk on my toshiba satellite
Insert the Toshiba Product Recovery CD and turn on the system while holding down the C key. This will allow the system to boot from the CD. Select either a Complete Recovery (this recreates all the partitions and formats each one, this may reboot the system several times depending on the size of the HDD and the number of partitions) or Standard Recovery (this just formats drive C:). This will then restore the operating system as shipped from the factory. A Toshiba Tools and Utilities CD is supplied for reinstallation of drivers and utilities without reinstalling the complete operating system.
Jul 16, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
93 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
