Question about Whirlpool Duet GHW9150P Front Load Washer
Metal Drum Ripped
I have a Whirlpool Duet Sport washer that I puchased in April 2006, and is thankfully still under warranty. We noticed our clothes were ripping and becoming stained with black/grey blotches. Upon further inspection we found that the metal at the back of the drum is ripped in several places and has jagged edges. The repair man said he has NEVER heard or seen this. Does anyone have a similiar story? We are hoping that they will replace the entire machine since the estimate is close to $1000...still waiting to hear from them. My guess is that it is a problem with the stainless steel when it was being made?
    President:
  • Whirlpool Master
  • 2,651 Answers
$1000 est????? parts are guarrennteed i would def call the manufacture.althoug ive neverheard of hte inner basket "ripping apart" im sure you should have some recouse with the manufacture, the machine new costs that now.did ithe tech give you that est with a straight face???? definatlly call someone else!!!!!!!
Posted on Feb 21, 2009
Whirlpool front load dryer - gives little holes in the tee shirts and other clothing's. Sometimes it feels like its burnt and sometimes its just holes and ripped
Check for sharp edges and pinch points on the ribs in the drum that tumble the clothes. I had my drum replaced under warranty.
Dec 14, 2016 | Whirlpool Washing Machines
F8E1 on my whirlpool duet WFW9150 front load washer. 4th time in 8 months...(bought brand new)
I too had the same problem and what I found (besides poor workmanship in the design of this washer) is that the pressure switch hose had rubbed the drum and there was a hole in it - leaking water, which I hadn't noticed until I sat there and kept re-running washer til a puddle had shown up below. They wire tied the top of the hose to the drum but at the bottom of the hose there were no wire ties and so the foam padding that was wrapped around just kept rubbing until it ripped and then left the hose exposed to the drum. They should have never tied the hose to the drum and should have attached the hose to the right cover. I will be modifying their design as soon as my new hose arrives.
Nov 28, 2010 | Whirlpool Duet WFW9550 Washer
Whirpool duet washer. Drum pulley loose
If the pulley doesn't fit the shaft anymore, it may have sheared a metal key between the shaft and pulley center. If it did, you may have to replace both the key and pulley. If the key is intact and the set-screw is only loose, just tighten the screw and you're home free. Make sure the belt has not been damaged--replace it if so. The belt should be fairly tight when things are back together.
Oct 28, 2009 | Whirlpool GHW9100L Front Load Washer
Duet Sport Washer fault code F-28
f-28 code is a serial communication error between the central control unit-ccu- and the motor control unit-mcu-. depending on the age under one year the unit should be under warranty, if so call a service man that care of the problem in warranty. if the unit is over one old you can remove the top and check all connections between the ccu and mcu.
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Inside of the dryer is cracking- huge holes!
the drum can be replaced but dont know if you want to pay for one they are probably expensive and 2nd if it is taking 2 to 3 times to dry clothes you have a vent problem which has caused the cracking of the drum probably cause so much heat build up in the machine your vent is stopped up and it isnt keeping the heat and moisture in the dryer which is a fire hazard please call a technician and please rate this
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer Banging During Spin Cycle
If the the drum feels loose in any way, there are three possible reasons:
1. The pulley nut has come loose. (easily repairable from the rear)
2. The bearing is bad (part of the rear tub).
3. The spinner has come loose from the basket (what you describe)
In cases 2 and 3, the entire drum/tub assembly will have to be removed, disassembled and repaired/replaced.
Check your owners manual for possible limited warranty. Contact Whirlpool for potential warranty repair concessions for case 3 if not covered under limited warranty.
Regards
reg501..The FixYa Team
Jun 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
436 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
