Question about Onkyo HTR500 Receiver
Wil not switch to dolby digital mode
Will not switch to dolby digital mode
You must use optical sound wire in order to reprduce dolby digital......You should have 2inputs on the back for this......plus the signal must be broadcasted in dolby digital.Such as HBO,SHOWTIME....they will tell you before the show comes on whether or not the movie or event is being broadcasted in dolby digital.Your unit will automatically change to dolbly digital once the show or event starts.Just make sure your input on video1,2,or3 is set to optical1 or 2.Just press the "Audio Sel" on the remote to change the audio source.But make sure the optical wire is connected first.....And just incase,make sure you are sending a dolby digital source to the unit from the sat reciever,cable box,playstation2.....make sure the dolby digital/optical option is on.You can find out what audio options you have in the menu screen.........or the redneck way.look on the back of the sat reciever/cablebox/playstaion2 ect...for a red laser light comming from these units.........i hope tht helps.
Posted on Apr 04, 2009
Cannot adjust tone controls , switch between ciienama, and music mode in dolby 2 and dts not functioning
dolby digital doesnt like people messing with the controls , so it doesnt let them do some things, and dts only works for dts encoded discs
Mar 07, 2013 | Audio Players & Recorders
Auto format decode means?
HI,
There are so many audo formats like Dolby Digital Decoding, Dolby Digital EX Decoding, Dolby Pro Logic Decoding, Dolby Pro Logic II, Dolby Pro Logic IIX Decoding, dts 96/24 Decoding, dts Decoding, dts NEO:6 Decoding and dts ES Decoding Stereo etc. What ever the AVR get a digital input It will decode the format and convert the same While it in the Auto format mode. If auto format is not selected it will convert the same in to stereo.
Ajin
Feb 09, 2012 | Audio Players & Recorders
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
Dolby digital
Dolby Digital includes several similar technologies, which include Dolby Digital, Dolby Digital EX, Dolby Digital Live, Dolby Digital Surround EX, Dolby Digital Plus, and Dolby TrueHD.
Dolby Digital, or AC-3, is the common version containing up to six discrete channels of sound. The most elaborate mode in common usage involves five channels for normal-range speakers (20 Hz – 20,000 Hz) (right front, center, left front, right rear and left rear) and one channel (20 Hz – 120 Hz allotted audio) for the subwoofer driven low-frequency effects. Mono and stereo modes are also supported. AC-3 supports audio sample-rates up to 48 kHz. Batman Returns was the first film to use Dolby Digital technology when it premiered in theaters in Summer 1992. The Laserdisc version of Clear and Present Danger featured the first Home theater Dolby Digital mix in 1995.
This codec has several aliases, which are different names for the same codec:
* Dolby Digital (promotional name, not accepted by the ATSC)
* DD (an abbreviation of above, often combined with channel count: DD 5.1)
* Dolby Surround AC-3 Digital (second promotional name, as seen on early film releases and on home audio equipment until about 1995/1996)
* Dolby Stereo Digital (first promotional name, as seen on early releases, also seen on True Lies LaserDisc)
* Dolby SR-Digital (when the recording incorporates a Dolby SR-format recording for compatibility)
* SR-D (an abbreviation of above)
* Audio Coding 3 (relates to the bitstream format of Dolby Digital)
* AC-3 (an abbreviation of above)
* Audio Codec 3, Advanced Codec 3, Acoustic Coder 3 (These are backronyms. However, Adaptive Transform Acoustic Coding 3, or ATRAC3, is a separate format developed by Sony)
* ATSC A/52 (name of the standard, current version is A/52 Rev. B)
Jun 16, 2009 | Ahead Software Computers & Internet
NAD 775 will not play surround sound from XBOX
try to calibrate the speakers from audessy rom menu,i did it and it lokes like it just needed to register all the channels,hope it helps.
Jan 29, 2009 | NAD T753 Receiver
No dolby digical in DVD mode.
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
Jan 25, 2009 | Yamaha HTR-5960 Receiver
TX-SR304 AV receiver
If you put DVD with Dolby Digital soundtruck it will show on your TX-SR304 Dolby Digital mode, and if you have DVD with DTS mode it will show DTS
Jan 17, 2009 | Onkyo TX-SR304 Receiver
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
Yamaha htr-5240 dolby digital problem
Is there switch from dolby pro logic/ surround / or analog/ digital?
Sep 27, 2007 | Yamaha HTR-5240 Receiver
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
Onkyo HTR500 Receiver Logo
315 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
