Question about Husqvarna Garden
My chainsaw wont run at full speed
It was running fine and i put new gas in and might not have been mixed exactly. pretty close though. also it shuts off after a few cuts and takes a moment to fire back up.
  • 32 Answers
Dump the gas and start over, pour some chem-tool in the tank slosh it around for a wile and dump it out, then refill your saw with NEW PREMIUM GAS and NEW OIL mixed at the correct ratio, it will take a few minutes to get the old fuel out of the line but then it will run like new, Gas and oil goes bad faster these days as oil company's no longer put in as much if any stableizer's
Posted on Feb 20, 2009
Regular gas (not 2 cycle) was put in my Poulan Pro chainsaw
If it was not run, or was shut down before it seized, drain the fuel
refill with 2 cycle mix (double oil if the saw had been run).
Start it and run under light load till empty.
if it seized a total rebuild will be necessary.
Oct 21, 2013 | Garden
Was using saw ran fine stopped and returned next day will not start fuel fine new plug filterers gas and air still wont start took to local chain saw repair shop they said that because it had water in gas...
check the carburetor. If you have a stiff diaphragm then it won't run.
I have seen them that behave just like that. They will run fine, turn it off for a few minutes then they won't restart. WD40 isn't going to get it to run either, try a small amount of mixed gas right into the carb. It should run for a minute until the gas you put in runs out then die. If it doesn't run then you have a bigger problem
Jan 30, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Stihl 090 Chainsaw carburetor get way too much gas at high speed, even though HS jet is completely closed.
You have an internal circuit leak in the body itself, my friend. Get a new carb, it's still going on a $1000 saw and will make it run like new again.
Jul 05, 2012 | Stihl Chain Saw 051 075 088 090 +
455 rancher wont rev
remove the muffler and try running it if ok open the muffler and clean off the screen
Apr 15, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Makita DCS6401 wont idle. When the gas is released the chainsaw shuts off.
Try turning the idle speed screw CW (not the jet screw marked L) one full turn to increase speed. Normally, this is set so that the chain stops moving, but the engine continues to run. Hope this helps!
May 13, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Wont run without choke being pulled out 1/4 .
INFO:
-Remove Carb and clean, you have a high speed fuel port clogged.
NOTE:
This would also be a good time to replace your fuel lines, Take photos before you start.
RECOMENDATIONS:
-Drain all fuel from the Saws fuel tank.
-Remove and REPLACE with a NEW spark plug.
-Remove and RELPACE with a NEW Air filter.
-With spark plug and air filter removed and fuel drained pull the starting cord many times 12 or so to ensure there is no fuel in the chamber and also check for a spark at the plug.
-RE-MIX WITH NEW FUEL your 2 cycle oil to the correct ratio in a clean fuel can. it is OK to dump some in the Saws fuel tank slosh around and dump out in an approved container for disposal.
-Hold off on putting back on the air filter until you have had it running.
Hope this Tip Helps.
R/
David
Jan 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
189 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
