Question about Extron Electronics Switching and Transmission System (tps150-1)
1989 honda accord transmission lost 5th gear
All my other gears work fine but the 5th just wont engage is it my tranny or is it my clutch?
Its very common..you only need a new tcm (transmission control module) thats it. also try unplugging your battery wait 15 seconds then plug it back up and that should restart your current one...but thats would only be a temperary fix.
Posted on Apr 30, 2009
  • camaroluvr69 Aug 04, 2011
    I am not trying to step on anybody's toes here nor am I an expert in this area but i am pretty sure if you have a 1989 honda accord that lost 5th gear you do NOT need a TCM. I am 100% positive Honda did not make a 5 speed automatic transmission in those days. It could be the bushing on the shifter and if not then it is internal and 5th gear is toast for good unless you replace the gear set.
My honda wont go into 5th gear
CHECK TO SEE IF LINKAGE IS INSTALLED WRONG
Dec 19, 2014 | 1991 Honda Accord
Tranny problem 1st gear wont work really and its hard to get 2nd gear but 3rd,4th,and 5th work fine plus reverse works fine. do i need to replace the clutch? or is it sumthing else that wont let me get in...
There is problem in the gearbox.The sincronizers for a first & second gear are on the same gearswitch.Need to change them.Forget about the clutch.
May 16, 2010 | 1998 Volkswagen Jetta
94 Accord Ex 2.2l Vtec will not engage passing gear
Sounds like it could be a problem something to do with the clutch perhaps? If the clutch or other components of the tranny are malfunctioning then it could very well be the source of quite a few elusive problems, and unfortunately the transmission on Honda's are known for hard-shifting, so i would have the transmission diagnosed just to see if everything checks out A-OK. Let me know how it goes!
Jan 06, 2010 | 1994 Honda Accord
My 92 honda accord will not go into 1st 3rd or 5th gear
check shift fork adjustment. make sure you bleed the slave cylinder.also check shift cable adjustment.
Apr 11, 2009 | 1992 Honda Accord
Cannot engage transmission from first to second gear
maybe has a broken linkage or the bolt came lose.
Check if you can engage hall the gears pushing the linkage by hand,engine ranning and same one pressing the clutch!that way you can have same idea wath is wrong?!
Dec 15, 2008 | 2004 Saab 9-3
1987 honda accord lxi 5 speed
Shop one of your pick and pull yards for a tranny. You will diffenatly have to pull it out to fix the gear,unless it is just in the shifter which won't press the shifter fork in the transmission far enough press the 5th gear into mesh(or into gear).
Sounds more like it might be in the gear shifter. Linkage worn or stretched, or a bushing out of the linkage. Take the plastic console off and look at the action of the shifter if it has alot of freeplay when trying to put it into 5th gear I would say, Get a junk yard shifter.
If you go into transmission It has to be pulled out of car to dissassemble it and it really is a job for a transmission specialist. Get a Junk yard tranny and just replace it. They usually give a gaurantee of some sort with the tranny.
Nov 07, 2008 | 1987 Honda Accord
Usually this is a linkage problem, and most often the rubber lined coupling between two rods in the linkage system. This fails as the rubber ages, and when it does you are unable to select some or all gears, and might be stuck in one gear!
Not too difficult to re and re, and part is available from Saab dealer at reasonable cost.
Coupling may be located inside the car, under the console, ahead of the gear lever housing, or on the other side of the firewall
Sep 03, 2008 | 1989 Saab 900 4 Door
No, you'll either have to replace the transmission or get it to a trans. shop to have it fixed.
Aug 16, 2008 | 1987 Honda Accord
1990 Honda Accord
IT SOUNDS LIKE YOUR CUTCH PLATE WHICH IS ULTIMATELY RESPONSIBLE FOR PUTTING THE CAR IN THE PROPER GEAR, SORRY NO QUICK FIX.
Aug 04, 2008 | 1990 Honda Accord
Open Questions:
Computers & Internet Logo
358 people viewed this question
Top Extron Electronics Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you an Extron Electronics Computer and Internet Expert? Answer questions, earn points and help others
