Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
My 80 gb hard disk was not accesible
I have loaded xp 64 bit os on xp 32 bit and the installation was done with some mistakes. later on I couldn't get opened either of the two, after the startup screen
I am not able to access any data in my xp version also.
  • elwayman02
    elwayman02 May 11, 2010
    This question should probably be put under Operating System problems.
    Scholar:
  • 180 Answers
Please edit through a dos bootable cd of windows 98. and it should have edit function on the cd. you can edit the boot.ini drive and modify the settings to boot from win xp32 bit by default, it must be second on the list.
if you cant succeed back up your important data from the drive and format the drive back up can be done by imaging softwares.
Posted on Sep 06, 2009
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
Video controller for windows 7
From Microsoft:
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
IF your Notebook meets all other specs you would need the the above device/driver. which may or may not be compatible with the Toshiba, which was pre loaded with Windows XP.
Thanks!
Jimm
Nov 22, 2012 | Toshiba Satellite A40-S161 Notebook
Will windows 7 run on my intel D945GCNL motherboard?
hello aravthebj, yes it can be done. when u need to install OS, first thing u need to know is system requirements, not motherboard specification.
Windows 7 minimum system requirements is: - 1 GHz Processor or higher - 1 GB RAM (32-bit) or 2 GB RAM (64-bit) - 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
check your processor and your RAM specification, if its fulfill that requirements then u can install Windows 7 on your PC.
if u need more information about Windows 7 then visit this site: http://windows.microsoft.com/en-US/windows7/products/system-requirements
hope this useful, regards.
Aug 28, 2011 | Computers & Internet
Will not install os windows xp , do i need a 64 bit operating system or both, 32/ 64 is the processor 32/64 bit loaded os on another hard drive and it comes up to the boot but will not allow me into the...
Check your system bios to ensure that ata is your chosen hard drive for installation. if you attempt to install on the mother boards default of ahci wich is windows vista or 7 default it will not work in order to install windows xp you must choose ata. as far as weather a 64 bit install is necessary, 32 bit will work on both but 64 bit windows must be installed on a 64 bit motherboard.
May 29, 2011 | Mercury KVM800M Motherboard
Does microsoft office and student 2010 work in xp
If you would be planning to use microsoft office and student 2010 on xp you have to have SP3 of XP. You may refer to system requirements given below.
Office Home and Student 2010 Component Requirement Computer and processor 500 MHz or faster processor Memory 256 MB RAM; 512 MB recommended for graphics features and certain advanced functionality.1 Hard disk 3.0 GB available disk space Display 1024x576 or higher resolution monitor Operating system
Windows XP (must have SP3) (32-bit), Windows 7, Windows Vista with Service Pack (SP) 1, Windows Server 2003 with SP2 and MSXML 6.0 (32-bit Office only), Windows Server 2008, or later 32- or 64-bit OS. Graphics Graphics hardware acceleration requires a DirectX 9.0c graphics card with 64 MB or more video memory. Additional Requirements Internet Explorer (IE) 6 or later, 32 bit browser only. IE7 or later required to receive broadcast presentations. Internet functionality requires an Internet connection. Multi-Touch features require Windows 7 and a touch enabled device. Certain inking features require Windows XP Tablet PC Edition or later. Speech recognition functionality requires a close-talk microphone and audio output device. Internet Fax not available on Windows Vista Starter, Windows Vista Home Basic, or Windows Vista Home Premium Information Rights Management features require access to a Windows 2003 Server with SP1 or later running Windows Rights Management Services. Certain advanced collaboration functionality requires connectivity to Microsoft SharePoint Foundation 2010 or to Microsoft Office SharePoint 2007. Certain online functionality requires a Windows LiveTM ID. Other Product functionality and graphics may vary based on your system configuration. Some features may require additional or advanced hardware or server connectivity; www.office.com/products.
Mar 18, 2011 | Computers & Internet
I have LatitudeD510 and my disk makes lot of noise. Its on Windows7 and I think the disk is a Hitachi - HTS541040G9AT00
HI,
chances are that you simply do not have the resources to run windows 7. These are the basic (recommended minimum), for windows 7
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor.
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit).
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit).
  • 1 more GB of RAM & 15 GB more HDD space to run 7 in XP Mode.
These are the typical resources that come with your machine.
D510HI
  • Processor Pentium M 1.73 GHz
  • Ram Installed Size 512.0 MB
  • Technology DDR2 SDRAM
  • Hard Drive 40.0 GB
  • OS Provided Microsoft Windows XP Professional
It would probably be advisable to go back to XP
Good luck
Jan 07, 2011 | Hitachi Travelstar 5K100 HTS541040G9AT00...
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
When we try upgrading xp to windows 7 the upgrading failed because our cpu is old can i upgrade my xp to windows 7 using a old cpu or use a new cpu
NO you cannot, on that same computer, no matter what OS, because, you MUST change your central Processing Unit, CPU. To allow Windows 7 to work correctly.
Feb 07, 2010 | Microsoft Windows XP Professional
We are unable to load window xp on hard disc, before we only find the 32 GB in 80 GB hard disk ... we successfully installed the window xp, but when jumper setting done in accurate place, it shows 80 GB,...
I think this model is still an IDE type. You set the 32GB limit then jump the settings to read the full capacity of the drive. If you are trying to load XP OS from a blank drive.
First prime the hard drive, you can do low level formatting and use third party software to partition and format the drive. on FAT32 partition you can only use 8GByte to make the drive bootable. Make it primary if I remembered it correctly and active. Or use the NTFS format.
You can use also if it have the manufacturers' hard drive utilities to check the hard drive integrity. I know they have it. It also equip with zero fill to renew chain and links of the drive. Then partition, format, primary and active. Then load your OS.
Check also your CD disc integrity, scratches do make a lot of troubles. And also your cdrom/dvdrom drive.
Oct 27, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
257 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
