Question about GE 24 in. GSD4320Z Built-in Dishwasher
Water pooling on bottom of dishwasher
I have a GE Profile Dishwasher Model # GSD4930Z04WW and I have a large amount of water that does not drain from the basin. When the cycle is done the water is actually over the heating coil so it doesn't dry the dishes. I know some water is necessary to keep the seal moist but this is way too much. I checked the hose for any blockages because most of the water is getting through but nothing was found. Check valve and sink work fine.
  • 38 Answers
Check the drain pump for debris that might be stopping the drain pump from working. Also could be faulty drain pump.
Posted on Feb 20, 2009
Ge profile dishwasher never cleans dishes and water is constantly in the bottom of the dishwasher producing a horrible smell.
DishwasherProblems - Water will not drain out
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 20, 2010 | GE Profile PDW8600J Built-in Dishwasher
Water at the bottom of the dishwasher
There is a check valve but it is not strong enough to overcome a large amount of water or waste water and is not a 100% seal. You will need to have your house drain cleaned so the water in the sink and disposer drain out properly.
To keep waste water from entering the dishwasher if you have drain problems in the future you can install an air gap. You can purchase an air gap at most any hardware or Big Box outlet, they come with instructions for installing and are a good idea if you have problems like this.
Apr 25, 2010 | GE 24 in. Profile PDW7800 Built-in...
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
Dishwasher will not fully drain
dishwashers are made to keep small amount of water in bottom so the pump will not lose prime
Nov 11, 2009 | GE Profile PDW8400J Built-in Dishwasher
Water is sitting in bottom of dishwasher after cycle is completed - fair amount of it
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | GE Profile PDW8000G Built-in Dishwasher
Water does not completely drain from dishwasher
Remove everything from the lower spray arm down to the deck. Keep track of everything that is removed: in what order, and which way to reinstall. Pay particular attention to the large screen at the bottom for being plugged as well as the several ports in the bottom deck. Check plastic parts for warping or cracking. Soak the large screen in a solution of white vinegar and hot water (1 to 5 parts vinegar to water) with some detergent added for about 1 hour. Because the water drain is a timed event, restricted water flow will prevent emptying all of the water.
Sep 06, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
My motto is "if it ain't broke, don't fix it.", but in this case we will make an acception. Check the inside of the washer for a float device sitting on the bottom. Floats can get stuck or bent over, make sure it goes up and down freely
Jun 28, 2008 | GE Nautilus 24" Built-in Dishwasher
GE 24 in. GSD4320Z Built-in Dishwasher Logo
839 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
