New video card installed lost audio
I bought a new geforce palit 9800 1gb and my mother board is foxconn p4m9007mb audio was fine until i installed this new video card then there it is i lost audio.  and there is a tiny cable comes along with it its called the audio loop and the f u c k i n g card dindt even vave a manual where to plug it and there is even no games included,, is that fare?? anyway my primary concern right niw is to have my audio back please hleppppppppppp anyone tnxxx..
I had the same problem, but it was easily fixed. The problem is not really uncommon -- the new video card tries to take over your PC sound as well as your graphics -- and they don't give you any heads up or options about it. Assuming you want to use your new card, the other advice in the previous post is not helpful -- removing the drivers through a System Restore will make your card useless.
One of the first questions you need to find out is if you are getting your sound on board through the Mother Board or through a sound card. One quick and simple way that might work is go into your Control Panel for sound, go to Audio, and under Sound Playback
try to restore your old sound setting.
If that doesn't work, you can look under your Device Manager (For XP, right click on My Computer, click on Properties, and click on Hardware, then go into the Device Manager). Look for the sound section and check for conflicts. Also right-click on your old default sound settings and try to re-install them or check for hardware changes. Then re-boot the system.
If that fails, then go into your PC Setup when the computer is first powered on. (usually by pressing the Esc key or one of the F keys, depending on your computer brand). Be careful with what you change since this can totally mess up your system if you are like a bull in a china shop. Where your sound section is, change the setting to "On" for onboard motherboard sound, instead of Off or Auto. That cured my problem instantly.
Posted on Apr 18, 2009
  • 107 Answers
You can find manuals & drivers here: Palit
I suggest first to try System Restore to restore your OS to previous day when you had your sound working.
Posted on Feb 20, 2009
I want to install my palit geforce 210 1gb ddr3 on my desktop with win7 & 3gb ram, model of cpu is aspireM5600. The problem is, when I installed the vdeo card driver and it requires to restart the
Using onboard graphics enter into the BIOS and set the setting to display to PCI-Express first then onboard if noexist PCI-E graphics.
Save and exit.
This will allow you to install your new graphics card to your monitor.
Take care!
damnor01
Sep 11, 2012 | Palit Microsystems Palit nVidia GeForce...
I have a asus p5g41-mlx3 mobo and i'm trying to install a palit 8400+ 1gb video card, but after installing and starting up my pc i get a blank screen. if i take out the card my computer works fine....
Check if it a jumper to disable the onboard video. If not, try disabling the onboard video in BIOS or selecting the option in BIOS to use a plugin card rather than onboard.
Where do you have your video cable plugged in? With the new graphics card installed, do you have video out of either connector?
Jim
Preston Computer Services
www.prestoncomputerservice.com
Jun 03, 2011 | Palit Microsystems GeForce 8400GS,, PCI...
I need a installer for my video card the brand is palit 7200GS i need it now plsss help me
1. Uninstall your old displsy drivers 2. Install you Garaphic card... 3. Install Nvdia Geforce 7200GS latest Drivers... 4. Boot your System. 5. enjoy...
Oct 14, 2010 | Palit Microsystems Palit GeForce 7200 GS...
How to connect hdmi audio cable from video card Geforce 9400gt to mother board foxconn G33M02
Your Geforce 9400GT doesn't have a HDMI outlet. It only has DVI, D-sub and S video. So I'm not sure what you're asking.
Apr 18, 2010 | Dell Vostro 200 Desktop Computer
Just received a Palit GeForce 8400 GS Video Card. It will not fit my mother board. Is my pc to old?
This is a PCI-E (PCI-Express) type video card. Older systems have an AGP (Accelerated Graphics Port) slot. You can verify this by looking up your system online and look at the specs to see which type of video slot it has.
Hope this helps,
-Tor
Dec 12, 2009 | Palit Microsystems GeForce 8400GS,, PCI...
The Palit Daytona Geforce 4 ti 4200 solution?
Check to see if you can upgrade the bios or set it to 8X if not, then your wasting the potential of the card.
Also, your power suply may not have enough power for all the devices you have hooked in, try unplugging the CD. floppy drive and try booting with just the main componets and see if it blows the PW supply again.
450W should be enough but may be not, depending on how many fans and other devices you have. Plus, the mainboard may not be able to handle it. Its shutting off to protect the system from getting fried.
Again, check the bios, you may be able to set it to a higher output for that Video card. Or even change it to 8x. It is quite old though, you may just have to put in for a new system. Keep all your receipts in case you have to take back that video card.
Feb 22, 2008 | Palit Microsystems PalitDaytona GeForce4...
Drive for foxconn P4M9007MB-8RS2H
You should indicate what OS you are using!
Oct 28, 2007 | Foxconn P4M9007MB-8RS2H Motherboard
Foxconn motherboard
very easy just type your mother board model number in the internet browser then u wil see all the driver u need audio to video...ex "B65MO1-G-6LS driver" ..
Oct 19, 2007 | Foxconn P4M9007MB-8RS2H Motherboard
Computers & Internet Logo
438 people viewed this question
David Payne
David Payne
