Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
USB Drive not detected by computer
Transcend 1 GB USB Drive not detected by computer. On connecting, the light blinks for 3-4 tims and then goes off. The drive does not appear in My Computer Section also. Under Device Manager>>USB Mass Storage Device, a yellow exclamation mark appears besides this. On updating the driver, the computer says latest drivers are already installed. Under device status, it says ''the device cannot start (code 10)''. Kindly suggest.
  • 107 Answers
Try to install latest chipset drivers for your motherboard. If you don't know what motherboard you have, you can download Everest and it'll give you all needed info.
If after install you still have this problem tell me, and we'll try to find a solution.
Posted on Feb 20, 2009
My external hard disk fall from a height of 1 mtr. Now it is not detected by the computer. When it is connected to computer, it is giving a sound just like running the hard dive, but the light in the drive...
  1. some internal damage it occur,
  2. The hard drive will work but not yet dispaly means inside circuit can be damaged is possible
  3. go to device manager and check whether all ports are in active or not
  4. another way to plug another USB port and then check it...
  5. if it's not the correct reason means check external hard disk..
Dec 24, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
My Transcend StoreJet 320 GB USB 20 Hard Drive is having a problem When i connected the drive to my laptop it got detected for sometime and then disconnected automatically
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
320 GB transcend external Hard dics is not at all detected
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Nov 16, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My 4 GB transcends jet flash pend drive is not detected
No softwares can solve it seems you have alreadyshot it by using it in usb slot that was not connected correctly
Jan 19, 2009 | Transcend (589307) Media
Detection problem
check it on other usb ports, also replace the usb cable
Oct 07, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Electronics - Others Logo
416 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
