Question about Astoria Argenta SAE/JUN Espresso Machine
I have an Astoria Argenta SAE1 Jun espresso machine. It has started tripping the circuit breaker. It does this when it has reached operating pressure (or nearly so). It does this without anyone touching it. When it happens there is a thump sound. It seems that the frame is vibrating - something like water hammer. Can you tell me which part is failing?
    President:
  • 1,618 Answers
Your problem could be one or two items (element or pressure stat or both). Remove the screw in the top of the P.stat(black or gray rectangle box with electrical wire going in from bottom about 4-6 inches long), lift the cover and check the terminals(turn power off). Make sure that there are no loose connections on the terminals.
On the element remove the wires that are connected to it and test with an Ohmsmeter.
Posted on May 30, 2009
Model number is SAE/2XL and I need a owners operating manual. we bought a used machine but they don't have a manual so,we want to know how the machine works and how to clean the machine. thank you if...
Could you please post the full model number and if you happen to have the serial number as well of your Astoria Argenta SAE-2 Espresso Machine? Thank you I await your reply
Rick
Oct 28, 2011 | Astoria Argenta SAE-2 Espresso Machine
Keurig b70 tripping circuit
Could be the breaker does not match up with the required amperage for the machine or you could be grounding out somewhere inside the machine.
www.kaldi.com
Apr 27, 2010 | Astoria Argenta SAE/JUN Espresso Machine
Looking 2 reinstate the electronic missing parts so it sautomatic
Yes the autofill is inside the control electronic box . If you know about electronic PCB board you migh need to replace a relay which is welded on the PCB board. Or you have toreplace the whole electronic contraol box which is expensive.
Please remember to vote for a rating for this answer, thanks
Nov 19, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Need manual/schematics for espresso machine.
Your coffee supplier will be able to provide you with one.
www.kaldi.com
May 28, 2009 | Astoria Argenta SAE/JUN Espresso Machine
We Have an Astoria SAE 2 Group and am looking to find the NSF label location on the machine. If i can't find that, how can I show health dept that it is NSF certified ?
On the right side of the machine next to the serial number is the most likely spot for the NSF sticker or tag depending on the model of the machine it may only have an ETL listing.
Apr 07, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Will not dispense water
If you're pump is working and your needle shows around 9 bars when running, most likely your Solenoid valve is bad. This can be caused from improper backflushing among other things.
We stock them ($60). Email me at fixya@kaldi.com with your contact information or from our website www.kaldi.com
Alex
Jan 30, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Astoria SAE-2
Contact Astoria and I'm sure they can provide one for you.
www.geec.com
Mar 14, 2008 | Astoria Argenta SAE-2 Espresso Machine
Astoria Argenta SAE/JUN Espresso Machine Logo
246 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
