Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
USB Drive not detected by computer
My USB Drive is not detected by the computer. On connecting, the light blinks for 3-4 times and then goes off. In device manager under USB Mass Storage Device a yellow exclamation mark appears besides this. ON updating the driver the computer says that latest drivers are already installed. Please suggest
  • 1 more comment
  • abhijit_tekr Feb 20, 2009
    Yes Sir, USB Ports are enabled in my computer and I have used the same drive just three hours back.
  • robertellent Feb 21, 2009
    I have the same problem on my ScanDisk 16GB Cruzer Micro USB Drive is not detected by the computer. On connecting, the light blinks for 3-4 times and then goes off. And In device manager shows nothing it's seem like U3 USB is not existing. Any suggest....
  • blueextc3221
    blueextc3221 May 11, 2010
    Are the USB ports enabled in BIOS?
    Have you ever used them ?
    Problem Solver:
  • 5 Answers
I have this happen regularly with many USB drives, not just Sandisk Cruzers. Sometimes removing it, waiting a few moments, and reattaching it (making sure to insert it straight, not at a funky angle, which can result in a confused system due to momentarily not being properly connected) does the trick. Rarely, I've had to reboot because the confusion wasn't so easily forgotten by the system.
Sometimes, I've noticed that plugging it into a different USB port does the trick, so if you have multiple ports available, try that too.
On Linux, with one particular USB drive, if I boot with it already in the port it works, otherwise, it has all sorts of random issues. Perhaps keep that in mind if none of the rest helps... though I would call that a malfunction, since only one of my drives exhibit that behavior, and considering it triggers unnecessary check-disk requests under Windows, perhaps that's a sign to toss that one.
Hope these ideas give you the tools to figure out what your unit likes. Funny how some of them develop 'personalities'...
Posted on Feb 23, 2009
  • 23 Answers
Don't forget to rate the overall satisfaction of this solution.
Remove the device by Right mouse click the device and select Uninstall.
Then Scan for hardware changes by clicking on the icon in the top menu that looks like a computer with a magnify glass.
Then close all of that out and then; Go Start> Control Panel> Administrative Tools> Computer Management Select Disk Management under Storage Look to see if your Drive is listed and what the Status, Layout, Type, and File System it has.
Right mouse click on the dive and click on Explore to see if your files come up. If yes, then perform a Change Drive Letter and Path.
Let me know what the status is.
Posted on Feb 20, 2009
The blue light keeps flashing on and off on my Seagate 4Tb XHD. It won't show up on the finder as connected. What causes that?
follow these steps:
  1. Make sure the computer and external hard drive are powered on.
  2. Safely remove the drive from the computer (if possible).
  3. Disconnect the external drive's USB or FireWire cable.
  4. Disconnect the power supply plug from the external drive.
  5. Power off the computer.
  6. Disconnect the computer's power supply cord for 60 seconds.
  7. Reconnect the computer.
  8. Power on the computer.
  9. Connect the power supply to the external drive.
  10. Connect the drive's USB or FireWire cable and check for detection.
If that does not correct the behavior, and if the drive is also not detected by your computer, the blinking light is probably a symptom of a larger problem. If those steps do not return the drive to correct function, it is very possible, even probable, that the drive has failed and needs to be replaced
Dec 22, 2014 | Seagate Computers & Internet
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
My hard drive can't be detected by device manager. All it does is blink and make a weird sound each time it blinks. What should I do?
good day.....seems this tips can help you...trace the sata cable if properly connected...but i'm sure the ticking sound is an indication of defective hard drive...inside the hard has a mechanical arm that goes up and down...this arm read the data..... it's better if you buy a new one....
Feb 13, 2011 | Seagate (ST9100801U2-RK) (9W3638556) 100...
My external hard disk fall from a height of 1 mtr. Now it is not detected by the computer. When it is connected to computer, it is giving a sound just like running the hard dive, but the light in the drive...
  1. some internal damage it occur,
  2. The hard drive will work but not yet dispaly means inside circuit can be damaged is possible
  3. go to device manager and check whether all ports are in active or not
  4. another way to plug another USB port and then check it...
  5. if it's not the correct reason means check external hard disk..
Dec 24, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
The hard disk is not working properly now a days some times it is been detected and suddenly disappered , light is also blinking and getting off what to do
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My computer is not detecting my LaCie Hard Drive
there is a usb port inside hd .box /many time it is damage and also usb cablle damage . so once time change this thing one by one to check. there is a rare chance to damage hdd. we have facinge many time same problem. this hdd and laptop hdd are same. only potr is diffrent, (nepal)
Oct 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My computer stopped recognizing My Book 320Gb. The blue light is out. When I connect it to a different USB port, the blue light blinks three times and repeats that pattern two more times. Then the light...
Do you hear the motor on the drive?It could be a firmware issue.your best bet is to call western digital if you are still under warranty,there website should have software which will enable you to test the drive or download any available firmware.
good luck
Jun 29, 2009 | Western Digital My Book Essential 500GB...
Ultra traveldrive not readable
Try the HD on another computer and see if it runs if it does then is is the port, Check the USB port with another USB item like a camera or something, If the port works then it is the drive. USB drives can and do burn out from time to time.
rmatheson@wowway.com
Sep 27, 2008 | Computers & Internet
Simpletech 500G HD
that means system wont support the drive or you are having problem with the detection or driver.
some system wont detect the drive with large size without drivers.
Jan 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Cruzer Micro 2.0 Won't initialize
Dear Ajax310 Fistly you must see if it initialises. If not then your drive need replacing. Is your pc connected to a network with many drives mapped? if so try this. 1. Right click on "My Computer", go to "Manage" and select "Disk Management" under "Storage" 2. If you see your USB drive, right click on it and select "Drive Letter and Paths" and select "Change" button and select any available drive letter. 3. You should have access to your drive, only if this the problem. Your problem description suggest this to be the problem or the drive would not power up.
Apr 20, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
285 people viewed this question
Top SanDisk Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
CiNi
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
