Question about Minolta Office Equipment & Supplies
Malfunction code C0045 Minoltal/Dialta 350F means what
Copier refuses to copy. Fax will not pick up.
  • 145 Answers
Replace the ozone fan motor...if it keeps happenin
Posted on Mar 01, 2009
I receive malfunction error code cof32
John,
Need to replace the developer and the drum. Ensure that the counters for the developer and drum are cleared first (in service mode) before pulling the image unit out (Right side of machine) then take the image unit a part replace the developer, cleaning blade and drum. DO NOT USE A VACUUM Cleaner to remove the developer, because static electricty from the Vacuum cleaner can destroy the sensor located below the image unit, which is what is giving you the code. but you should change the developer and drum first. After that you run the F 8 procedure in service mode. Ensure the FAX and printer cables are removed do not want a Print job or fax to come in before running the F 8 or you will start over with a new developer. If you think you can do all this GO for it, if not get a tech out to do it.
AND NO JUST RESETTING THE COUNTERS WILL NOT WORK!!!! The machine use the counters to determine the correct voltages to certain assemblies. If you reset the counters that tell the copier parts are new when in fact they are old and you get codes and image issues.
Apr 30, 2016 | Minolta DiALTA DI2510F All-In-One Laser...
C3710 error code for Minolta color copier Di200f/di251f/di351f ?
First Sir/Mam, Please let me explain the Di 200f series is not a color copier! What is the model the code C-3710 is not associated with the Di200f series.
Aug 29, 2013 | Konica Minolta Minolta Dialta Di200f...
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Dialta Di183 error message C0045
replace fusing unit cooling fan try the web site below as a start for the part Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Sep 11, 2010 | Minolta DiALTA Di183 Copier
I am getting error code C0045 on the Minolta Di2510f
Error C0045 indicates a cooling fan motor malfunction. Either the cooling fan motor or the master board needs replaced. I have a copy of the service manual on PDF if you would like to attempt the repair yourself.
Mar 31, 2010 | Minolta Di251 All-In-One Printer
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta CF900 Photocopier
CODE C0900, DOES NOT PASS COPY, FIERY FRONT COVER BROKEN OFF AND VERY DIRTY, also you may want to try and look at the 3rd drawer lift perheps there's somthing blocking it
Aug 29, 2007 | Konica Minolta DiALTA CF910 Copier
474 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
