Question about Hitachi 60VX915 Rear Projection Television
Tv powers off and on after operating for about 1 hour
When set is turned on after (say overnight rest) it operated just fine for about 1.0 hours...then it will turn itself off for about 1-2 min. then will then stay on for abouit 3-5 min. and then turn off again...t5his cycle3 will continue till i manually turn set off....after a period of rest, i can turn it back on and then the same scenario repeatss itself...the ligt flashes ''BLUE'' several times quickly then slows down after a few seconds and will then turn back on...there no ''RED'' power litghts litt up as when nor,al turning on..whaTS GOING ON? i REPLACED BULB ASSY. APROX. TWO MONTS AGO
    Problem Solver:
  • 11 Answers
Same happened to me with my old panasonic set. It was a dry-joint. You can try re-soldering the circuit.
Good Luck.
P.S. - Check the Power Suply area closely.
Posted on Feb 20, 2009
I hear an clicking sound on my Sony KDL-40Z5100 every so often when it is powered off. This occurs hours after it has been powered down. Is this normal or a problem?
This is not a problems,it is a normal operation for most LCD tv.The clicking sound,u hear is it the tv power supply board are dis ingaging out of the input a/c power supply source to the rest of the tv electronics operation boards.
Apr 30, 2011 | Sony KDL-40Z5100 LCD TV
Power went off and when it returned unit will not progress from the Hello message
Remove the power plug and keep the set un-switched for few hours/overnight. If there is any resetting mentioned in the manual please try and reset the TV using the method described.
Now it is possible that the Tv has hung up after the surge on power after the power cut.
This might have corrupted the operating program and hence it might need a reset.
Feb 15, 2011 | Televison & Video
My tv will play fine, then shut down on its own. After a few minutes I am able to turn it back on, and it will run fine the rest of the night. Lateley, this has been occurring after only a few minutes of...
The tv projection lamp has been inside the tv like about 2 year?Tv been on and used like 4 or 5 hours daily?It time to replaced the tv projection lamp.And the Ballast board might be the cause and the problems too,might require replacing too.The Ballast board job,it to help to ignite the tv projection lamp.
Jan 06, 2011 | HP Pavilion MD5020N 50" DLP HDTV
After several hours of inactivity, the screen on my SyncMaster 192n goes black, and the only way to turn it back on is by hard re-booting my computer. Sometimes even ctrl-alt-del doesn't work, and I have...
My guess is your video card driver has been altered and is causing the problem. Try rolling back the driver before reinstalling the monitor. Here is a link to the manual for your monitor:
From the above manual: "The PowerSaver system operates with a VESA DPMS compliant video card installed in your computer. Use a software utility installed on your computer to set up this feature".
Mar 18, 2017 | Samsung Syncmaster 192N 19" LCD Monitor
How to set time on jvc kd-r210
Setting the clock
  • Press and hold SEL (select) for more than 2 seconds. "DEMO", "CLOCK H", "CLOCK M", "DIMMER", or "AMP GAIN" appears on the display.
  • Set the hour.
  • 1. Select "CLOCK H" (hour) if not shown on the display.
  • Set the minute.
  • 1. Select "CLOCK M" (minute).
  • 2. Adjust the minute. Using the Control Knob
  • Finish the setting. To check the current clock time or change the display mode.
  • Press DISP (display) repeatedly. Each time you press the button, the display changes as follows:
  • • During tuner operation:
  • • During CD operation:
  • • During power off:
  • The power turns on and the clock time is shown for 5 seconds, then the power turns off.
The tv model number is hitachi 46w500. the dvd picture is stuck on one screen and now the dvd won't eject.
Remove the power off and let the set rest for about few hours. Now try out to see if the DVD releases.
If the picture is still with the old memory of thelast scene then the processor has hung up.
You must have to release the DVD by opening panel if a reset of an overnight power on the set does not work.
Oct 30, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
I need to change the time on it.
You can try the following steps
Setting the clock
1 Press and hold SEL (select) for more
than 2 seconds.
or “AMP GAIN” appears on the display.
2 Set the hour.
1 Select “CLOCK H” (hour) if not shown on
the display.
2 Adjust the hour.
1 2
3 Set the minute.
1 Select “CLOCK M” (minute).
2 Adjust the minute.
1 2
4 Finish the setting.
display mode
• During power off:
Thanks for using Fixya
Jul 27, 2009 | JVC KD-G200 CD Player
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Hitachi 60VX915 Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
