Question about HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 and Vista, to scan a text, not a picture
HP PSC 1315 and Vista. Ok then, the scanner is working at last, via paint. But what i needed was to scan a document and save it in my pc... A text, not a picture... I need the WORDS. Should I go scanner shopping?
  • Anonymous Mar 02, 2009
    Cannot get scanner to work at all... I too, need to scan a documet and save it in my files.. Is there a quick easy solution?
  • 25 Answers
Just to try....
The Scanner software should have an option to choose image or text, image and text etc.. Look for that first.
Do a scan but before you do and run through the process as you normally would.
Put the printer/scanner CD in the carriage cancel auto-start. My HP different type but... does not always see/grab ALL of the scanner files on an install. Sometimes however, it will go looking for the files it needs and grab them off of the CD when it actually NEEDS them. When you try to actually to the scan. Otherwise the printer probably works perfectly right.
If you want to check it out just for the sake of it. Look in Windows explorer - control panel and see if there is actually a scanner listed or just a printer? Good luck!
Posted on Mar 01, 2009
I have downloaded the most recent printer driver to my HP PSC 1315--however it still does not communicate with my Readiris OCR scanner software. Help?
Way # 1----Click on the following in this order:
1. Windows
2. All Programs
3. Accessories
4. Paint
5. File Menu
6. From Scanner or Camera
7. Scan
Way # 2----Click on the following in this order:
1. Windows
2. All Programs
3. HP
4. HP Solution Center
5. Scan Picture
6. Select File type from file type drop down arrow
7. Scan
8. OK
Please rate my response!! Thanks, SF
Jan 28, 2010 | HP PSC 1315 All-In-One InkJet Printer
I just bought a new computer with vista and I can not download my scanner program. Is there any way around this or do I have to by a new all in one
You can scan with either the Windows Fax and Scan or Paint programs. Open either one and under File, choose import from scanner (in Paint it's Scanner or Camera).
I hope this helps.
Dec 11, 2009 | HP PSC 1315 All-In-One InkJet Printer
I've Hp psc 1315 all- in-one. I can print, copy but can't scan. My hp solution center is not working???????????
Probably a driver problem. For Windows XP or earlier, go the HP website and download current driver. For Windows Vista, the driver does not enable scanning. A workaround is to use Paint. To open Paint, select:
All Programs-->Accessories-->Paint
To scan the image, select:
File-->From Scanner or Printer
In the Select Device window, click on the HP printer then click on OK. In the Scan Using HP.... window, select a color option and click Scan. Wait for the image to be scanned in and then use Paint to manipulate the image or save it.
Nov 21, 2009 | Cars & Trucks
My HP PSC printer will not scan on my pc with,
Probably a driver problem. The solution for Windows XP or earlier versions of Windows is to go to the HP website and download the driver for the printer. For Windows Vista there is no driver that enables scanning. The workaround is to open Paint, select:
To import the scanned image, select:
In the Select Device window, select your printer and click OK. In the Scan Using HP..... window, select a color option and click Scan. Wait for the image to be scanned into Paint. Then you can manipulate the image using Paint or save it.
Nov 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
How do I get the scanner in my HP Psc 1315 to work
You can scan with out any HP software also using the below steps.
Make sure that the printer is connected to the computer perform the following steps;
Steps for scanning in Windows XP: 1. Click the Start (Windows) icon.
2. Click All Programs.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Steps for scanning in Windows vista:
1.Click the Start (Windows) icon.
3. Click Windows Photo Gallery.
4. Click File and then click Import From Scanner or Camera.
5. Click Import.
6. Click Scan.
Sep 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Scanning pictures to my computer
Please Install Scanner Software. then only you can able to scan pictures
Aug 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
How to scan a paper by using vista window and hp1315 printer
I ran into this problem myself. The scan button does not work on my printer. I chatted with a HP technician about it. He gave me some solutions to this problem. There are two ways to scan a document.
1. Windows
2. All Programs
3. Accessories
4. Paint
5. File Menu
7. Scan
1. Windows
2. All Programs
3. HP
5. Scan Picture
7. Scan
8. OK
Both of these worked for me. I was able to rotate the scanned picture in Paint. I hope that this helps you resolve your issue.
Thanks!
mannu_rakesh
Jul 24, 2009 | HP PSC 1315 All-In-One InkJet Printer
Scanner hp 1315
Hi -
I don't have a Mac, so not entirely exact on your solution. But, I do have a suggestion to try -
if you use a scanner, you probably have a photo editing software of some kind (like Photo Shop, Paint Shop Pro, etc etc). Within that program, there is an option to obtain the image from a scanner. You should be able to use that function instead. I know that with my WinXP, I could import from the scanner in Paint Shop Pro MUCH easier than trying to use the actual HP buttons on the 1315.
Please note that the 1315 will also only scan flat items well. If it is 3D, like jewelry or oddly shaped objects, you'll only get fuzzy-edged pictures. The 1315 has no depth perception, no matter what setting combination you use. Not HP's finest moment, for sure. I had this printer for a month or two before I was fed up, and went back to a separate printer and scanner! : /
May 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
HOW TO SCAN ON HP PSC 1315
i have a Vista system and an old hp 1315. the CD driver that came with it includes some very useful software that cannot be installed in my laptop. according to the hp website, that's because Vista comes with a compatible software for my hardware. checking Windows Help & Support gave me this solution:
Open to Windows Photo Gallery, click File then click Import from Camera or Scanner.
i did exactly that and it worked!
i hope this was of some help.
Jan 26, 2008 | HP PSC 1315 All-In-One InkJet Printer
PSC wireless scanning
Print servers do not usually allow scanning as XP and Vista.
May 30, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
178 people viewed this question
Ben Johnson
