Question about Targa Computers & Internet
My computer is stating no signal - Targa Computers & Internet
  • 13,433 Answers
Hey,
The monitor of the computer is not getting a signal from the computers video card.
this can be caused by a faulty video card, or just the computer not starting up properly.
instead of replaceing parts I would recommend you take the computer to a professional or someone knowledgeable in computers to get it fixed.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 20, 2009
Monitor keeps stating no signal
Need to eliminate possible causes. Easiest way is to try your monitor on another computer, if it works then that is ruled out. Try your computer with another monitor. Try another cable between computer and monitor (both yours and borrowed one). The problem can be the monitor socket and wiring, the computer socket, wiring or program and finally the connecting cable.
Oct 28, 2015 | Computers & Internet
When I put my computer on it comes up with scanning no signal and the screen stays black with the little light in the corner is yellow but sometimes leaving the computer on by itself
The monitor is stating that there's no signal from any device. It could be that the monitor cable is unplugged from the back of the tower, or the graphics card could be bad. "Scanning" suggests you're using a smart TV rather than a monitor. In that case, you may need to change the setup type to VGA, DVI, HDMI or whatever type signal the computer sends.
Oct 18, 2015 | HP Pavilion Computers & Internet
Monitor states No signal. this is a new computer, just today
Make sure you are connecting the monitor signal lead to the correct signal output on the rear of the machine. Some desktops have extra video out connectors when they have a graphics card fitted. If yours has a graphics card the display connector will be away from the back USB ,audio and keyboard ports and near to some silver pop out panels near the bottom of the tower.
Apr 20, 2013 | Acer Aspire m5640 PC Desktop
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
Cant find signal from cable - Logo comes up in greyscale then states "no signal" Cable checks out fine.
Connect a different monitor to your computer, to see if the video-card in your computer is working.
Connect your monitor to a different computer (desktop/notebook) to see if the monitor is working.
Jan 21, 2010 | ViewSonic VA1930WM LCD Monitor
Can't receive wireless signal from main computer
you have to make a new wireless connceton and instal the serial number off of the wireless modem in to the new computer to set it up to recive and send on the network you also have to set up network shares and need to be the administrater to do so,
May 31, 2009 | Computers & Internet
US-1641 audio interface "no valid signal"
check the console in control panel and assign the ports ur using.
Jul 16, 2008 | Tascam US-1641 Sound Card
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
No signal
turn on computer.
Jan 06, 2008 | Acer Computers & Internet
What is the triggering signal to power on the monitor?
Most modern monitors use the Horizontal sync line to determine when to go to standby.
Aug 18, 2006 | BenQ V773 17" CRT Monitor
Computers & Internet Logo
Top Targa Computers & Internet Experts
David Payne
David Payne
Are you a Targa Computer and Internet Expert? Answer questions, earn points and help others
