Question about Smeg S351X/5 Electric Single Oven
Siemens oven fan not working
Siemens oven HB55M50B light bulb keeps going out and fan not working although oven heats up
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: smeg oven
Sounds like you need a new oven element fitting.
Posted on Dec 08, 2008
No lights on oven, fan working no heat
No heat and fan working usually means the heating element has failed. Before you go down that road get the oven light checked as well in case there is a central problem. If by no oven light you mean the internal oven light is not on then that is just a bulb replacement. Make sure you get a heat resistant or original spec one though.
Jun 02, 2015 | Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Need to put new bulbs and elements in fan oven
the bulbs are screw fit normally Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jan 12, 2010 | Ovens
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
Fan working grill working just no heat in siemens oven
hello the first thing that we need to look at is the electrical box thats is outside and see if there are any more braekers tripped. the clue is that everything work except the heat. thats 208/230 volt and the rest of the oven is 115 volt. e sure to take the breakers and push them all the way to off then back to the on position. if thats is the problem now you are going to have to call a service man to check out what is shorting and causing the breaker to trip.
Dec 23, 2008 | Ovens
Botom oven not working
Hi
The oven element is probably faulty, I assume the fan is still working.
Nov 23, 2008 | Ovens
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Smeg S351X/5 Electric Single Oven Logo
70 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
