Question about Craftsman Garden
Need schematic for Craftsman rototiller
I'm looking for a repair manual or an exploded view of the drive and tiller components on a 6 HP Craftsman rototiller with counter rotating tines. I have model, serial and stock no.s available if required.
  • tmartinell Feb 20, 2009
    Thanks MrFixIt-jerr, I went to sears.com and entered my model no. but it came back with "no matches found". I'm just trying to determine if there is any practical method (or need) of occassionally greasing the drive chain, inside the enclosed housing, without completely disassembling the tiller body. There appears to be a very small grease relief hole on one of the sides, above the "thru shaft" location, but there isn't anything that allows for additional grease to be applied. Do you know if these tillers are designed to be maintenance free for life in regards to drive chain and sprockets? Thanks.
    Hi MrFixIt, I'm not entirely sure, but I thought that you had replied to someone else with a similar question (I got your contact information from a response you made to them) that the chain in the tiller drive mechanism was factory "greased". I checked both sides thoroughly for a fill and drain plug and the only thing I found were the long bolts that hold the housing sides together and the small relief hole. I'd say the hole might be large enough for a medium to large syringe needle to fit through. There did also appear to be some sort of carrier shaft that I could see only the very outer face of which would make sense as a filler hole but there was no way of removing or depressing that item.
pranaclimbin
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
steve_lima
  • 181 Answers
SOURCE: need manual for craftsman 6 hp tiller model
you can get a manual from sears. if you go to the sears parts web site,put your model number in and go to the decal section the manual is there for a wopping $3.92 part number is 166007. i hope that helps you out.
Posted on Mar 12, 2009
  • 86 Answers
SOURCE: Rototiller won't engage into gear
You will need to split the gear case if iam not mistaken it has chain drine the chain links break and you have to replace them
Posted on May 13, 2009
  • 246 Answers
SOURCE: trying to locate manual for my craftsman front tiller mod #134202
Hello leonard3878:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual, Operators Manual or Shop Manual" in the Search Box and it will Direct you to the Page you Require.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 17, 2009
harlan301
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
Belt drive diagram for ford rt5
Exploded view of rototiller available at New Holland website.. Area with decals has belt path diagram.
http://partstore.agriculture.newholland.com/us/parts-search.html#epc::mr55011ar111419
Belt goes around motor pulley and tiller pulley and above idler pulley, which is in the middle. When putting belt on, it is easiest to put around motor pulley first and tiller pulley (the large one) last. Belt is 3/8" x 27" v-belt. Idler pulley is available too, only under Lawn Boy part number, which is found on parts list at New Holland site. Just had to perform repair. All parts found on ebay.
Hope this helps!
Rob (Sterling Heights, MI)
Mar 21, 2013 | Garden
Craftsman rear tine rototiller transmisson repair 917299641
You can go to searspartsdirect.com there is chat line there and maybe they can help.
Oct 14, 2017 | Craftsman Garden
Do you have a manual for a might mac tiller to show how the belts are installed?
I was able to find the web page for the download for the pdf file you need. It is a manual with exploded views for several models including the 5.5 hp model. Just go to the page and download the file and you will be in business!
http://www.ardisam.com/download/5055.pdf
Oct 30, 2010 | Ardisam 5.5 Hp Rear Tine Rototiller
Trying to locate manual for my craftsman front tiller mod #134202
Hello leonard3878:
Good Luck
Respectfully
jbridger (John)
May 17, 2009 | Craftsman Garden
May 09, 2009 | Garden
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Need manual for craftsman 6 hp tiller model 917293310
Mar 10, 2009 | Craftsman Garden
Garden Logo
901 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
