Question about Kenmore Elite 45986 Front Load Washer
Power on but cannot do not work when press Start button.
Power on but do not start. It sometime show F 14 on the screen, sometime show DL .
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
HI, my copier AR-122EN is not working it shows 4 and H when I press he start button.
From the keypad area press # * C * The machine will enter a diagnostic mode.
Then enter the number 14 as if to make 14 copies. Press start and follow the directions to clear the code.
Mar 11, 2011 | Sharp AR-5316 Advanced Digital Imager...
Hi :My Tomtom does not start from the main push botton. My tomtom kind ONE XL.S
Assuming you have pushed the ON/OFF button, and had no success .... and have also pushed down and held down the ON/OFF button for a few seconds ... up to a minute, and your GPS still does not turn on ... then, you want to make sure the battery is fully charged before you try to start it again.
Note that it may not start while it is plugged in (to a power source) ... because it uses the battery as the primary source of power.
Plug the GPS device into the charger (wall adapter or your USB computer port) ... to charge the battery for a few hours... preferably more, like 24 hours or more. Then try to start the device again.
Feb 10, 2011 | Tomtom GPS
Display window is flashing F 6
c i c i 14 press start copier should go blank and restart if not press c cassettekey 0 cassettekey 14 start try that i means interupt c =clear
Apr 13, 2010 | Sharp AR-M205 Copier
My son's 5315 will boot up, then hang, do a memory dump, then restart at the screen that asks how you want to start Windows, i.e., safe mode, normally, etc.
hello
If it is showing the memory dumping message then you RAM is dying.
you soon have to replace it with a new one.
If it shows some other error message then please mention.
Thank you
Aug 16, 2009 | Acer Aspire 5315 Notebook
Error code H2 on screen
Hello sir; H2 code require reset procedure as follow;
1, press "#", "interupt", "c", "interupt" these 4 keys.
2, enter 14 then press start.
3, turn power off and back on .
Jan 28, 2009 | Toshiba e-Studio 161 Copier Copier
How to reset Asus PC-DL Deluxe BIOS
Remove the Lithium Flat Battery from the motherboard, then start the machine. Let it run for about 5-10 seconds and then turn it off and put the battery back in.
Some motherboards when you try to power it up without the battery, will not turn on. Press the power button 2-3 times and then place the battery back in and it should achieve the same results.
Dec 11, 2008 | ASUS PC-DL Deluxe Motherboard
Doesn't start
hi, if ur screen turns white, it could be any problem starting from ur LCD to motherboard or as u said a virus. to assist u in a right way i need to know what exactly is happening between that short duration between pressing the button and white screen. most importantly is anything else comming up on the screen before the white screen.
cheers
Oct 12, 2008 | HP OmniBook 500 Notebook
Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Mar 17, 2008 | Sharp AL-1641CS Laser Digital Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Kenmore Elite 45986 Front Load Washer Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
