Question about La Pavoni Europiccola EPC-8 Espresso Machine
Adding pressure gauge to Pavoni Europiccola
I would like to add a pressure gauge to my Europiccola similar to what comes on the Pavoni Professional. It would seem that, for starters, I just need to replace my sight glass cap screw with the sight glass gauge nut that comes with the Professional. Yet I see indications on different web sites that, although this may have been possible with older Europiccolas, the sight glass cap screw size was changed on newer Europiccolas specifically to prevent this change. Out of curiosity, I contacted one Pavoni parts supplier and asked if the size of the sight glass cap screw has changed over time and asked if there were different versions of this screw. The response, while somewhat vague, indicated the size has not changed over the years. If this is true, it would seem the Professional pressure gauge nut should fit into my Europiccola, making the addition of a pressure gauge possible. What can you tell me about this? Any help is greatly appreciated.
    Novelist:
  • 137 Answers
  1. in the boiler water is heated and presured up to 1.5 bar
  2. when water gets in lever and non return valve closes becouse you press the lever down, your energy is used to get high pressure, it should be frpm 7 up to 9 bar.
  3. SOLUTION==if you search way for modifying, you must consider that you must pump directly to group, not to boiler. in this case water will be cold (becouse comes from pump). you will need boiler in boiler to heat the water wich comes from pump before it gets to group. this is bit more complicated than you thought may bee but it is only solution.
Posted on Mar 30, 2009
Dissasembling Europiccola Pavoni
The boiler is tightened down via a big brass or plasitc ring which is threaded look on the page linked below
Apr 12, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Dissasembling Pavoni Europiccola
Try looking at this site its really good helped me do various repairs to my La Pavoni Pro
http://www.francescoceccarelli.eu/lapavoni_faidate_eng.htm
all the best P
I need to pull up very ******* the lever for water to come out.
Again sounds like the seals are damaged and or need some lubrication and a service link below to a good site
dr pavoni
Apr 04, 2014 | La Pavoni Europiccola EPBB-8 Espresso...
Water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
First Cup Is Cold From La Pavoni Europiccola
If the machine works great after the first cup then it is possible that the heat for your first espresso went to heating the portafilter or the cup used to brew into, try warming the portafilter first by running some hot water through it first.
Apr 09, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Professional, Chrome, 16 cup capacity Europiccola
You have to take a screwdriver and try to bend up the platic, be careful so you not break it.
Aug 20, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
No pressure
I have the same problem are awaiting reply from la Pavoni direct...I suspect there is a fualt with the pressure gauge as it is steaming up too!!
Jun 10, 2007 | La Pavoni PC-16 Espresso Machine
La Pavoni Europiccola EPC-8 Espresso Machine Logo
908 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
