Question about Brother ML-100 Typewriter
Margins I need to reset the left and right margins, i had read to press "code" and "mar rel keys" and backspace to where i want it, same thing for right but it didn't work. Do you have any other suggestions?
  • publicnotary Mar 01, 2009
    i need the manuel to help me move the margins
Posted on Jun 13, 2009
Left margin stuck at center of page What to do besides reset margins? Can't back up to reset the left margin
You have to push the Mar Rel key then backspace to the new margin and press the Left Mar key
Jun 05, 2014 | IBM Wheelwriter 6 Typewriter
How do you reset the margins
Hi:
to reset the left margin press the Mar Rel key on the left side of the keyboard once. Either space or backspace to the point where you want to reset the margin and press the Left Mar key once. To set the right margin just space to the point where you want to reset it and press the Right Mar key once.
Andrew
Jun 21, 2012 | Lexmark Wheelwriter 1500 Typewriter
I can not figure out to delete existing tabs. I can not figure out how to set the left margins and right margins. HELP
To clear alltabs; tab allthe way to the right, hold the tab clr key press return.
T set margin Go to L. mar, press mar rel key, space or backspace to desired location, press l. mar key.
DickyO
Dec 10, 2010 | Lexmark Wheelwriter 15 Series II...
How to set margins
after hitting the return key, the carrier goes all the way to the left margin. If you need the margin to move even more to the left, hit the margin rel key and backspace to the desired position and hit the mar left key. Same for the right margin, use the space bar to move the carrier all the way to the right margin and press the margin rel and move the carrier to the desired position and press the mar right key.
Jan 27, 2010 | Royal Satellite 40 Typewriter
How do I reset the margins for bigger paper?
Hi:
Most of these small portable typewriters have dual function keys. You need to find the keytop that has Margin Release on it. It might say Mar Rel. If this in in a color that is different then what ever else is on the key then this is a daul function key. What this means is that you also have to look for a code or mode key. Once you find that hold that key down while pressing the Mar Rel key once. Then release both keys and use the backspace key to back up through where your left margin is currently set. Once you have done that you can reset the left margin at that point by findind and pressing the Left Margin key. Note that the left margin key might also be a dual function key.
You can extend the right margin by spacing to it and then doing the same procedure above , but this time release the right margin and space throught it and then reset it where you want it.
Good Luck
Andrew
Jun 26, 2009 | Brother ML-300 Typewriter
I have a IBM Wheelwriter 5 and I need to re set the margins
Return to the L. margin, press mar rel key backspace to the location for L. mar., press L.mar. key. If this dosen't work check to see if the L & R mar keys have been switched I've seen this befor. Other wise you probably a keybourd,
DickyO
May 03, 2009 | IBM Office Equipment & Supplies
Reset Margins
on the upper L.H. side of the key board ther is a button marked MAR REL. turn typ. on press the return key then press the MAR REL key back space to move the carrier backwards or space bar to go forwords. when you are at the spot you need to be fined the button that reads L MRG. press it know your left hand margin is set,
know space the carrier over to the left by the space bar if it stops befor you whant it to press the MAR REL button space to where you whant.
now you have another button saying L MAR
press that and you left hand margin is set. Or the R MAR has small green letters saying L MAR if so you need to hold down the CODE key wile pressing the R MAG key ( any thing in green on key board can only be actavated by the code key ) hope this works
Jan 21, 2009 | Brother GX-6750 Typewriter
What keys do I use the change the left and right margins?
You set the margins by putting the printhead where you want the margin set, and holding down the CODE key, push the key under where L MAR or R MAR is printed, (above the top keys on the keyboard) depending on whether you want to set the right or left margin.
If you want to set the left margin to the left of where it's set, hold down the CODE key and push the key under MAR REL. Then using the Backspace (or spacebar, if you backspace too far) position the printhead where you want the mar. set and holding down the CODE key, hit the key under L MAR.
Setting the right margin works the same way.
Oct 27, 2008 | Brother GX-6750 Typewriter
Margins
L. margin - return to current mar. press mar. rel. key, backspace to the wanted location press L. margin key.
R. margin - space or backspace to desired location press R. mar key.
The margin keys are on the left side of the keyboard.
DickyO
Jul 10, 2008 | IBM Wheelwriter 30 Typewriter
Margins
Position the carrier wher you want the margins by the space bar or back space and touch the left margin or right margin key button as needed
Sep 19, 2007 | Swintec 7040 Typewriter
Brother ML-100 Typewriter Logo
125 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
