Question about Kenmore Elite 45986 Front Load Washer
Problem Code F 14
Power on but do not start. It show F 14 on the screen.
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Posted on Sep 13, 2010
Have Sharp - AR-5516 and H5 error blinking on the screen
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Mar 28, 2015 | Sharp Office Equipment & Supplies
How can i clear H 4 error code on my sharp AR-153E coppier. your help please.
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Mar 20, 2015 | Sharp Office Equipment & Supplies
Codes f 14
f14 code is SRAM board initialization...press 0 and 8 while holding ,then power on..wait for the AJ ...appears then press 388 start and 389 start power off ..
May 25, 2013 | Konica Minolta Office Equipment & Supplies
1 have a xerox copier model XD120F Had apower outage when copier cam back on screen is showing a H4 and not powering up thanks Joe
Hello
Since the problem occured after a power outage,you should try resetting the H code.
Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code should vanish and your copier should work well.
Apr 17, 2011 | Office Equipment & Supplies
Sharp AR M300U error code H5-01
Press P * c * or # * C * the diagnostic screen will appear, then enter the number 14 as if to make 14 copies, then press enter or execute . then power the machine off and on.
Once you enter 14 and start, follow the instructions on the screen, they vary a little on how to clear the code. But that will reset it.
Jul 17, 2010 | Sharp Office Equipment & Supplies
Just plugged it in from being stored and it is blinking H 4
On the control consol. Press #,*,c,* the display should pop up with a screen to enter a code. Press 14, then enter 1. If the screen comes up blank, then enter 14 as if making 14 copies. Press start, and the machine should reboot and come to ready.
On your machine I believe the screen will go blank and you just enter 14 then start.
if not and a screen comes up with 00-00 displayed, enter 14 then start, then 1 then start.
Feb 16, 2010 | Sharp AR-M205 Copier
Error code H2 on screen
Hello sir; H2 code require reset procedure as follow;
1, press "#", "interupt", "c", "interupt" these 4 keys.
2, enter 14 then press start.
3, turn power off and back on .
Jan 28, 2009 | Toshiba e-Studio 161 Copier Copier
Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Mar 17, 2008 | Sharp AL-1641CS Laser Digital Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 14-372 after power on
Chain 14 has to do with the scanner not passing self test, not comming to ready.
CCD Module, exposure lamp or one of the scanner baords.
Jan 03, 2008 | Xerox DocuColor 12 Printer
Kenmore Elite 45986 Front Load Washer Logo
19 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
