Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Ice maker is crushing ice when cube ice button is on
I have a side-by-side frigidaire (not sure of the model number) and the ice dispenser is crushing the ice cubes even though the cube ice button is on. The crushed ice button wasnt even pushed when it started to do this. I dont know how to fix or what to look for.
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Posted on Sep 05, 2009
  • 6,784 Answers
Hi, the problem is in the selector switch itself. if its touch pad, you will have to reset the control board by unplugging the until for 3 min. if its a physical switch, it may be faulty and will need to be replaced.
Posted on Feb 20, 2009
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
jeffbvegas1
  • 520 Answers
SOURCE: LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
Posted on Jun 28, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
Ice maker frigidaire only making crushed
What is the model number of your refrigerator the ice container that has the auger in there has a lever that goes through the bottom of the ice container and then into an opening in the back where it slides into Square opening that moves the lever up and down when you switch from crushed to cubed it changes the position of that lever. Open the door and press the light switch to turn off the light and have someone pressed the dispense ice button with the ice bucket out can you see that part move up and down. Switch it from crushed to Cubed while watching and pressing the dispense ice button. Does it moved? Is there ice build up over that area that may prevent that actuator for moving the lever?
Appliance 911 Sea Breeze
Jun 20, 2016 | Frigidaire Refrigerators
Can I disable my crushed ice maker
Good Morning Friend,
You want to disable your crushed ice maker on your Frigidaire refrigerator, model# FRS26R4A. You will need to push the "Cube" button for the ice dispenser to stop dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire FRS26R4A Side by Side...
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Frigidaire model PLHS237ZDBA Ice maker dispenser won't switch back to cube ice it keeps crushing ice though its on Cube ice?
The rod under the ice tray was not in the correct position when the tray was inserted back into the freezer after removal. I get cubes now.
Feb 08, 2010 | Frigidaire PLHS237ZD Stainless Steel Side...
Frigidaire ice maker always crushes the ice
Solenoid that switches blades from crushed to cubes is most likely not working and should be replaced
Sep 05, 2017 | Refrigerators
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
ICE Maker stuck in dispensing crushed Ice
That means that the evaporator fan system that releases the the ice cubes is not working.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 29, 2008 | Frigidaire GLRS267ZC Side by Side...
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker will not dispense ice cubes only crushed ice
sounds like the circuitry on your Cubed Ice button has malfunctioned. Contact the manfacuturer for a solution.
in the meantime, u can grab the Cubed ice manually.
hope this helps!
Jun 16, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
1,175 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
