Question about Dell 1700n Laser Printer
How do I change fuser assembly for Dell 1710n printer
  • 10 Answers
If you don't have the part already, I'd suggest getting a refurbished unit under warranty, or a newer like-model with a new warranty attached. When you buy a new printer, you get brand new toner and warranty coverage as well. It's really a better deal. The fuser is located at the top of the printer near the exit feeder. I'd recommended contacting Dell if you really want to pursue replacing it.
Posted on May 29, 2009
Dell 1710n need cd
Hello you can download the installation software here:
http://www.dell.com/support/drivers/us/en/04/Product/dell-1710n
Please select your windows system.
Remove previous installed programs, before you install the new software.
The setup for the static ip, you have to select this under the install of the printer program.
Good luck
Feb 01, 2013 | Dell 1710n Laser Printer
Need fuser part number for 1710
Dell Part # RC442 available everywhere on internet
Jan 05, 2011 | Dell 1710n Laser Printer
Printer dell 1710,paper is always sticking,We used different kinds of papers and they all stick and now all the lights keeps flashing
If by sticking you mean jamming. One cause could be worn pick up rollers or possibly an issue with the fuser assembly.
Jul 06, 2009 | Dell 1710n Laser Printer
Paper is getting stuck in paper tray when printing
Use you equipmente ina dry place. Paper absorve humidity, and with heating passing by fuser, sometimes get stuck.
sory for bad english.
Best Regards!
Jun 24, 2009 | Dell 1710n Laser Printer
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
Jams
Check the sensor at the rear of the fuser. Sometimes sensor gets stuck.
Aug 12, 2008 | Dell 1710n Laser Printer
Paper cannot pass the Fuser/pressure rollers
We have many of the 1700N printers and have found that the 2 paper pickup tires must be in good condition to avoid frequent jams. I would highly suggest replacing the 2 paper pickup tires if this printer has a lot of copies on it.You can slip the tires off of the plastic roller and see if they are shiny. If so, replace them.
Paper jam / Dell 1710n
Do this You want to check the paperpath so first run a test page you will hear the paper pickup if you stick your ear to the paper tray it should pickup paper within 2 clicks any more than that that means you would need to change the bottom roller and the pad on the tray to be safe, to print a job the printer is timed to do this so if your paper is not picking up in time it will jam (also your fuser the part that heats up the toner on the paper it has a time limit to heat up if it's slow or don't heat up at all you will get a paper jam plus if that happens take your finger and run it across the paper if toner on your finger it's you fuser
Sep 12, 2007 | Dell 1710n Laser Printer
1710n Printer - poor print quality
You need to inspect your drum unit as well. If you can line up the marks on your page with the drum then you will need to replace the drum unit. If you donot find any problem with the drum unit then check the fuser unit on the back of the printer. Be very careful when checking the fuser since it is EXTREMELY hot. Good Luck
Mar 06, 2007 | Dell 1710n Laser Printer
Dell 1700n Laser Printer Logo
1,595 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
