Question about Nikon D70s Digital Camera
NIKON D70 FLASH WONT LOCK DOWN. - Nikon D70s Digital Camera
  • 60 Answers
With the flash popped up, look under the flash head to make sure the little hook that comes up from inside the camera is not broken off. If it is, the whole top of the camera must be removed to repair it. If the hook is still intact, look for the very small hex socket under the flash head. Very gently turn it 1 or 2 clicks and see if the flash head will stay down. Do not push in too hard while turning it! If not, turn it 1 or 2 more clicks and try again. This adjusts the surface inside the head where it latches. If you do this enough times to where the adjustment has completed a complete circle and it still won't latch, it would need to be repaired by a camera repair shop because the solenoid is out of position.
Bob Kilbourn
www.CameraRepairs.com
Posted on Sep 21, 2009
I will likely be shot down by those who know more, but this worked for me. As stated before, there is a hex screw that you can adjust. A great suggestion!!! However, the adjustment didn't work on mine so I took the cover off the flash head by removing the two screws that are underneath the head and then pushing out where the hinge is. ( *** I also got shocked twice by touching the flash leads/wiring and it hurts like a mini taser - look up how to safely discharge the capacitor for the flash !!! *** ) The hex screw is a flat disk like a plastic washer with different thicknesses (kind of like the old spark plug gapper that you could put on a keyring). It is held in place by a metal plate spring, thus you can push the screw up with the hex screwdriver/allen wrench. I positioned the screw so that the narrowest part of the "washer" is where the catch tab would be able to slip over it but it was still too thick. I used a razor blade to carefully shave the washer down to size. I tested it a dozen times pushing on different areas of the flash hood to make sure it would work. Then put it all back together. Other than the danger of being shocked and using a sharp razor knife on really small parts, this is something I think most people could handle if they are used to tinkering with things that everyone sends to the shop for the professionals.
Posted on May 27, 2012
Is this flash to use on a nikon D70 camera. It works on a F70 but on a d70 its not functioning
The Achiever Flash 630AF is for Film Cameras and will not work properly on the Digital D70 camera.
Nov 29, 2010 | Achiever 630AF for Nikon TTL Flash
Hello I have an sb800 nikon flash (4 years old) that has just started to act up....seems as my shoot goes on the flash seems to get very warm and wont always fire... Im using energizer rechargeable 2500mah...
Are you shooting those 20 pictures in rapid succession? If so the flash is saving itself by shutting down. If that is not the case, check your batteries with a battery charger to see if one may be weak causing a strain on the others. Call Nikon 1-800-645-6689
Aug 26, 2010 | Nikon Speedlight SB-800 TTL Flash
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
Promaster 7500 D Digital Flash usage with Nikon D70
you need to go to your cameras menu and set your flash function to m ( no to ttl) set it in full M and then it works hope it works that works for me i had the same problem
Dec 05, 2008 | Promaster 7500DX for Nikon TTL Flash
Flash
If you shoot in Auto mode, the camera will not allow you to turn off the flash when it senses that it is needed.
To use the camer without the flash, change the mode to Program ("P"). Once it's in P mode, the flash will not fire as long as it's in the down position. When you want to use the flash, press the speedlight release button (the one with the little lightning bolt near the mode select dial).
Sep 26, 2008 | Nikon D70 Body Only Digital Camera
Nikon D70 flah not working, used to
I had this problem a while back, but was fortunate to get it fixed under warantee as it was less than six months after Nikon repaired my D70 for the "blinking green light of death" fault.
I'm afraid this is a repair job for Nikon or an autorized workshop. It is most likley the flash tube. If you fancy taking your camera apart (I warn you it would be a fairly difficult job) then please be aware that you may get a significant electric shock from the flash capacitor, which will remain charged.
Feb 18, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon d70 flash stopped working
Well, you are not going to like my answer. The troubleshooting guide for the D70 says it could be 1 of several PCBs (printed circuit board) being faulty or the connecting FPCs (flexible printed circuit).
You'll need to locate a local repair person or use the reapir service search here on Fixya. Nikon USA repairs will be $$$$
Feb 15, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
D70 mirror lock up
I'm looking for the source of this same problem. I was able to get my d70 unstuck by:
1. Set to full manual mode.
2. In the menus set mirror lock up to yes and then press shutter release.
3. Turn camera off and then back on
Hope this helps you!
Nov 26, 2007 | Nikon Cameras
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
Nikon D70s Digital Camera Logo
458 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
