Question about HP PSC 1410 All-In-One InkJet Printer
Printer begins to print fine and then all of the sudden it begins to print red lines across the picture.
  • HP Master
  • 13,433 Answers
Hey,
reinstall the drivers, first uninstall the previous ones, they are all available here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=441115&
let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 21, 2009
  • HP Master
  • 19,396 Answers
Try re-installing the drivers from page below.
Also try a replacement usb cable , if the cable is losing connection during printing you may get same problem.
If that does not fix the problem, then the printer has a defective logic board.
Here is the support page. Try downloading and installing the drivers again , and replacing the USB cable.
If this does not fix the problem, then the printer is defective.
HP PSC 1410 All-in-One Printer
Will print a printed page with picture fine, try to print photo or any picture comes out with lines across
print heads need cleaning. check the tools/options maintenance for the print head cleaning option. It should be able to do a "self clean"
Mar 22, 2015 | Epson WorkForce 630 All-in-One Printer...
HP LASERJET 3800 PRINTS THIN BLACK LINES ON PICTURES
that print head is clogged,
do the clean cycle shown in the manual;
new cartridge time if cleaning does not work.
all things work last week but now.
nothing new here and for sure pesky printers
and for sure not used every day. (this keep them going more reliably)
made back in 2008, so is getting long in tooth and on most this full cleaning of the whole printer is advised. ever do that?
per manual?
rtm?
https://support.hp.com/us-en/product/hp-color-laserjet-3800-printer-series/500934/manuals
Oct 09, 2017 | HP Color LaserJet 3800
My prints are red with lines Why
Cleaning an ink-jet printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Thin white lines across printouts indicate that the ink nozzles need to be cleaned.
  1. p 1 Collect the supplies you need: a soft cloth and cleaning fluid made for plastic. (Water is fine in most cases.)
  2. Step 2 Check the printer manual. If the manufacturer has provided specific instructions, follow them.
  3. Step 3 Turn off the printer.
  4. Step 4 Dampen the cloth with water or cleaning fluid.
  5. Step 5 Wipe the outside of the printer, making sure that no fluid gets inside.
  6. Cleaning Cartridges or Ink Nozzles
  7. Step 1 Use the cleaning buttons on your printer if it has them.
  8. Step 2 Initiate cleaning through the printer software.
  9. Step 3 Open the printer software by double-clicking on a printer icon or opening a document and then selecting Print from the File menu.
  10. Step 4 Click a button labeled Options, Troubleshooting, Clean Print Cartridges, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.)
  11. Step 5 Click a button labeled Head Cleaning, Run Nozzle Check, Clean Print Cartridges or something similar to begin the process.
  12. Step 6 Follow the instructions on your screen.
  13. Step 7 Repeat the cleaning process if the results aren't satisfactory.
  14. Step 8 Go to your printer manufacturer's Web site for detailed instructions on manual cartridge cleaning and interior cleaning.
Nov 15, 2009 | Epson Stylus Photo R300 InkJet Printer
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
White line through print on label
Use a q-tip dipped in alcohol to clean the printhead.
Lou
Aug 01, 2008 | Brother P-Touch 1180 Label Printer
Red lines across page
What program are you using to print the pictures? Try cleaning the print heads and using another program.
Feb 20, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP PSC 1410 All-In-One InkJet Printer Logo
Ben Johnson
