Question about Canon PIXMA iP1600 Printer
Repair the narrow plastic strip that spans the corner to the printer head has come off, how do I put it back on the printer? I see one end hooks on the end of the track , where does the other end go?
First remove the flip up lid and the paper support tray then remove two small phillips screws one infront of the black ink cartridge the other on the far right. Then use two regular screwdrivers to pry off the cover start at the backside underneath you will see two tab slots walk the screwdrivers about 1" apart until the top is free (you will think that it is going to crack but the plastic is flexable and strong)
There are two metal tabs on both sides they are held in place by the tension from the plastic strip. Check strip ends make sure they are not broken and the strip is not frayed slide back in place adjust tension by bending tabs out slightly reassemble and print a test sheet. I had to run the test 2-3 times to reset the printer. If this does not work you need a new printer.
Posted on Feb 23, 2009
Scanner locked
The left of the scanner glass/window, there is another narrow window where you should be able to see the scanner head. The scanner head on mine was locked at a slight angle in this window. an extremely thin kitchen knife in on the right side of the narrow window, between the edge of the window and the narrow plastic strip. able to push the locked end of the scanner head down with the knife by prying the knife up and down between the glass window and the plastic. The end of the scanner towards the back of the printer was locked on mine and it was slanted towards the left side of the printer. After a couple minutes of prying and pushing down on this end, it popped free!
Sep 08, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Plastic strip above the printer head
IT IS EASY TO PUT IT BACK AGAIN. HOOKS WILL BE THERE AT TWO ENDS.
Apr 05, 2010 | HP DeskJet 932c InkJet Printer
MY CHILD DID TAKE OUT THE STRIPE, WHICH IS USED BY PRINTER TELL THE CARTRIGES, WHERE THEY SHOULD STAND. I WAS ABLE TO PUT THE STRIPE BACK ON THE HOLDERS, BUT CARTRIGES ARE STILL NOT THERE THEY SUPPOSE TO...
not had one of these in bits but i take it you mean the transparent plastic strip with line on at the back of printer. just hooking it back is is not going to work you need to get the printer head over to left hand side of printer and the plastic strip runs through a slot in the printer head so the printer head knows it location
Mar 10, 2010 | HP PSC 2175 All-In-One InkJet Printer
There was a carriage jam error and a long narrow gray piece with a small hole on either end is now completely out of the machine. Help
Sounds like you are refering to the encoder strip. It is a thin clear piece of plastic with little black lines all the way accross the length of it. The printer has a sensor on it that reads these lines so that the carriage assembly knows where it is inside the machine. It is usually spring loaded on one end of it. Both ends of the encoder strip have a notch on it. One side of the encoder strip hooks onto a fixed mount through one of the notches, the other side hooks onto a spring loaded mount. If it is all the way out the strip needs to be threaded back through the sensor on the back of the carriage assembly(the thing you install the ink cartridges into). Hope that helps a bit. It is a simple problem for a tech to fix but could be more difficult if you are trying to do this without removing any of the covers.
Oct 31, 2009 | HP PSC 2510 All-In-One InkJet Printer
Plastic thin strip about 15" long has came off my HP1410
That sounds like the belt that moves the printer cartridge carriage back and forth. Unfortunately, you will most likely have to purchase a new printer, because repairs for that will be prohibitively expensive.
Sep 02, 2009 | HP PSC 1410v All-in-One Printer
Printer does not print but on screen message is "printer cradle cannot move". Print would move back & forth @ one end, moves to the other end to repeat the back & forth movement and then stop with...
This generally occurs when the tracking ribbon becomes dirty and the print head travel cannot be tracked. Open the cover as you would to change your ink cartridge and locate the clear plastic strip behind the print head. Very gently wipe the ink residue from the strip using a cloth damp with water. You should be able to move the print head manually enough to clean the entire strip. Again be very careful as the strip hooks on the left side and is very difficult to reattach.
Aug 11, 2009 | HP DeskJet F380 All-In-One Printer
IDE ribbon pulled out!
The "IDE" cable you refer to is the "Flat Flexible Cable" or FFC in Epson parlance. It connects to the Main Board. To remove the top cover, apart from the obvious fixings at the back, you need to release the two hidden hooks at the front of the cover. For this you will need a strong thin strip of metal - an old fashioned ladies nail file is ideal, or a very thin screwdriver might do; it also takes a bit of a knack to do this, so be patient. You will need to lay the printer on its back, but note that in this position, waste ink can spill out of it. Make sure you lay it on a good thick layer of newspaper. Underneath at the front near each corner you will see a narrow slot.
Insert the metal strip in one, at an angle such that you touch the front wall of the case. Slide the tip of the strip up the case wall until you feel an obstruction - this is the hook. GENTLY prise the hook away from the wall and the case will open a bit; do not use too much force or you will break the hook - it is only thin plastic.
Repeat the process the other side. Complete the case removal by GENTLY pushing in the hooks at the back. When you replug the FFC into the main board, make sure you thread it correctly around the guide posts, so that it can move backwards and forwards correctly when the print head is moving. Test the printer before you put the top case back on. You may feel it would be sensible to purchase a Service Manual before you tackle this task - they
are pretty cheap.
Oct 17, 2008 | Epson Stylus C48 InkJet Printer
A THIN plastic strip about 1/4 X 16 INCHES LONG HAS BECOME SEPRATED FROM MY X4270 PLEASE ADVISE HOW TO FIX
This clear plastic strip is responsible for telling the print head where it is horizontally. Pls note that it has black stripes almost like bar codes. Both ends of this encoder strip normally would have holes for hooking up to lock tabs on both ends. What is important is that this strip is embedded in a slot at the back of the print head that reads the bar codes/locations.
This page may shed additional insights.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 21, 2008 | Lexmark Office Equipment & Supplies
924 Printer
'Band?'
Does it look like a strip of clear plastic with very fine vertical lines?
Or, does it have teeth molded into it?
The former is used to determine the position of the carriage and is normally mounted through a narrow slot in the carriage and should have small holes at the ends.
One of these ends will be mounted on an immobile hook, the other will have some kind of spring to maintain a little tension on the band.
These will be located at opposite ends of the printer beyond the normal travel of the carriage.
Some printers want these oriented in a particular way; front/back left/right but most don't care much how they are mounted.
Look for markings that might indicate a specific orientation.
If it has teeth, it ain't a band :-( it's the drive belt and the printer will have to come apart to replace it with one that doesn't have any 'ends.'
Don't know the specifics of your printer and the difficulty in replacing these varies widely, depending on the stupidity of the designers.
Aug 27, 2008 | Dell 924 All-in-One InkJet Printer
Plastic strip fell off
Hi, if you open the open the printer, unit to gain access to install ink cartridge, if you see the metallic end which has got a hook on both the ends left and right side. the ink cartridge runs between the strip from left to right which should be connected above the ink cartridge meta rod.
< ------------- >metal hooks on left and right above the cartridge rod
======= __ cartridge rod
Let me know for further info.
Feb 05, 2008 | Dell 810 All-In-One InkJet Printer
Canon PIXMA iP1600 Printer Logo
50 people viewed this question
old marine
old marine
