Question about Avaya Corded Phone avaparp18d
Programming Page Button
I am unable to use the page button. The digital screen reads: "CO Not Assigned" Does anyone know how to fix this? Much appreciated!
  • Avaya Master
  • 2,460 Answers
You could look in the station user's guide and program paging. This may work, or not, if you're paging internal and outside do this:
From your phone press Feature 00 the button and then Intercom *70.
If you don't want all the idle phones in group 1, but just the outside speaker, press 70 alone.
I'm not positive, but you may have to delete the button in centralized programming if it is already assigned a "CO" line.
Centralized programming is done from extension 10 or 11 and involves the system manual and knowing where the overlay buttons are.
Post back if you need a basic Partner ACS manual or try www.avaya.com for system manuals.
Carl
Posted on Feb 20, 2009
How to program the page button
Can you please be a little more specific? Are you referring to assigning the paging feature to a button on the phone or programming the actions the system performs when you press the existing paging button on the phone? Normally, when you press the predefined paging button on this phone the system prompts you to select where your paging output goes. Depending on how your system was set up it may ask you to select "set", meaning when you select this soft-key the system will sound a short alert tone through all of the speakers in all of the phones connected to the system then allow you to talk through all of the phone set speakers. The other option is to select a soft-key that directs the output of the paging to an external PA system that is connected to the NAM through a punchblock connection. You can usually also select "both" which directs the output through the phone sets and the PA system. I am not certain what, if any system programming might be involved - I am fairly certain that if your system has not been connected to a PA system the paging function is just available to output through the phone set speakers. If your phones have no buttons assigned to the page feature then you'll need to refer to the system programming procedures to find out which feature code is assigned to paging and then access it by pressing FEATURE + the paging code or assigning the paging feature code to an unused button.
Oct 16, 2013 | NorStar Meridian M7310 Phone
I have the message CO Not assigned ,How can assig CO? panasonic kx-t7730
Press program button, select button you want to program, dial 0 then dial CO number as in 001 according to which CO line you wish to program. If you are not sure which CO line is missing, check the button programming by the same method. Press program button then any programmable button and it will be identified in the LCD screen. The CO lines may be 2 digit if you have an older system as in 01, 02, etc
Jan 26, 2011 | Panasonic KX-T7730 Corded Phone
Programming VMT Button
Hi Ashley!
Check out page 158 of your OM. It's the list of codes for features access and it requires a CO button. Press PROGRAM 94107 STORE.
Carl
Dec 23, 2009 | Panasonic KX-T7731 Corded Phone
Intern page counter for hp deskjet 3650
Turn the printer on, Press and hold down the POWER button while holding down the power button Open and close the top cover four times and then release the POWER button
It will print a page and in that page just look for Line Number 21 which will say like - PX = XXX
XXX is the number of pages this printer has printed till date
Oct 16, 2009 | HP DeskJet 3650 InkJet Printer
KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
Carl
Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
CHANGING THE TIME ON PHONE
I can give you the fast answer and the slow answer. Fast one is to go to the main phone, press PROG and dial **1234. The system should go into programming and you will be looking at system program 000. ENTER. From there, using a combination of the SEL, FWD and CONF keys, you should be able to navigate around the time change, using ENTER or STORE to save it.
The arder way is to grab the manual here http://www.public.carl.airpost.net/TDA/TDA_PTPM_32.pdf and start reading it from page 12 then follow the instructions on page 16.
Keep in mind that TDA programming is usually done from the master phone, or any phone assigned programming status. It may be all or NONE.
Carl
Apr 15, 2009 | Panasonic KX-T7636W Corded Phone
Can't figure out how to print test page when not connected to PC
Please follow the steps given below to perform a Self test:
1. Turn off the power by pressing the Power button once.
2. Press and hold both the Start button and the Power button.
3. Once the screen displays Mfg Menu enabled, release both buttons.
4. Press the Mode button three times. All the indicator lights will go out and the screen will display LCD button test.
5. Press the up arrow (Up arrow button) twice. The screen will display Single Test Page.
6. Press the Start button once. The self test will begin. The printer will stop once the page has printed in full.
7. Turn the printer off and then back on to disable the manufacturer menu (Mfg Menu).
Apr 05, 2009 | Lexmark X3480 All-In-One Printer
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
We have the Panasonic KX-T7433 model of phones at our office. Yesterday I set about to re-programme some of the extensions and now, as a result I have lost the outside line for the phones that I have been...
I just found this, which had the process for programming a CO button as a one-touch. And it worked. It's a bit easier to follow than the panasonic manual so hopefully it will have an answer.
http://www.command-a.com.au/Portals/0/Panasonic%20816%201232%20Quick%20Referance%20Guide.pdf
Jul 23, 2008 | Panasonic KX-T7433B Corded Phone
Black screen
OK, this might sound stupid, but I had the same problem with a similar camera and I had accidentally pushed the Display button. I was about to give my camera up for dead. Try pushing it (the little button on the bottom back that says Disp on it). Does that bring your image back? If not let me know and I'll research further.
Jul 13, 2008 | Nikon Coolpix S1 Digital Camera
Avaya Corded Phone avaparp18d Logo
730 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
