Question about Compaq Computers & Internet
Evo D510 won't stop telling me (no fan connected) fan is turning
I get no fan connected prompt when I turn on my evo D510 the fan is there but turns at a noticably slower rate than I would have expected, first time I have ever owned one of these and still have not found mb (climber on bottom in white letters) manufacture any info on either? don't want to use clear cmos switch (#2 on bank of 3) till I know more than I do so far.
    Scholar:
  • 60 Answers
Good call, don't clear the cmos. You probably have a bad fan. It's not that uncommon for fan bearings to go bad. One of the three wires on the fan tells the motherboard the rpm of the fan. If it's running below a certain rpm, the PC won't boot in order to protect the cpu from overheating. You should be able to pick one up for cheap, around 10 bucks or so? Make sure you buy the correct size. These fans are measured in mm. Tiger Direct, 80mm case fan... 5 bucks.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=38043&Sku=S457-1007
Posted on Feb 20, 2009
My dell latitude d510 cpu fan won't start when i turn it on
sound like a faulty fan or the fan's power lead check all connections soldering and plugs for secure dust free connections or replace the fan
hope this helps
Oct 09, 2012 | Dell Latitude D510 Notebook
Compaq Evo Problem!!
hi
this probleme causing by graphic card put the new one and try
Feb 19, 2012 | Compaq Evo D510 PC Desktop
My Compaq evo d510 c system turns on it gives one short and two long beeps with no video. please help. thanks
What i did,
I replaced VGA card with the new(taken from the other dead pc) one and also l found one RAM was dead, so i had to remove it and the PC was working fine..!
According to the technical reference manual for the evo D310, 3 beeps is a memory problem.
Check page 52 of this document.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00658282/c00658282.pdf
Aug 14, 2011 | Compaq Evo D510 Minitower (Open Box)...
Compaq evo no drivers for ethernet xp sp1. cannot connect to internet.
Hi. Here is your driver for your Compaq Evo D510. Driver is for Windows XP Pro. Please click here.
May 29, 2010 | Compaq Evo D510 Minitower (Open Box)...
My compaq evo d510 cmt keyboard lights flashing constantly
first problem its a compaq go buy something else no seriously buy something else
check your bios settings F10 for compaq if i remember corectly might be F2
http://h18000.www1.hp.com/products/quickspecs/11349_na/11349_na.HTML
http://reviews.cnet.com/desktops/hp-compaq-evo-d510/1707-3118_7-20719364.html
i mean com on 533 bus and dosnt saport multi core cpu's
my 2004 dell 200 mhz buss saports quad core wth
if its not a bios setting replace your keyboard good luck
Feb 19, 2010 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
When i put on my computer, this message apear : 511-cpu fan not detected. I have a Compaq Evo D510 CMT and i use Windows Xp. Thaks for the help
This will likely be caused by a loose connection, if you look inside the machine there should be a cable running from the fan on top of your cpu to the motherboard. If thats disconnected or loose then plug it back in and all should be right with the world!
Dec 24, 2009 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
I have compaq evo d510 and facing multi-boot problem
First of all you need to install Vista on the 1-st partition. After done you can install linux on the free partition choosing manual instalation. The bootloader should be Grub, that works fine with Vista.
Dec 14, 2009 | Compaq Evo D510 PC Desktop
Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Nov 19, 2009 | Compaq Evo D510 PC Desktop
Compaq evo-d510-boot problem
What have you recently plugged in as new hardware ? this F1 response indicates that a piece of hardware is not properly configured to run , and F1 is the offered option to go to CMOS to complete the installation.A most likely item will be a USB powered piece of hardware.
Nov 27, 2008 | Compaq Evo D500 PC Desktop
Computers & Internet Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
