Question about Whirlpool Duet GHW9150P Front Load Washer
My whirl pool washer is pouring water out the bottom of the soap drawer. It goes all over the floor and not into the washer. How do I find out what is blocking it?
  • Anonymous Feb 22, 2009
    soap dispenser
  • Whirlpool Master
  • 2,651 Answers
You can remove the inner dispensor assy and loo down the dispensor nozzle, the next thing you can check is yo can remove the boot form the outside of the face of unit, slightly peel back outer most ringnad youll see a sprig clamp holding it in place, afeter removing the clamp you can unpeel the boot for the forn of unit and youll see the "fill tube" in the top left corner, id imaginr that either a washrag, or dryer sheet, perhaps even a cpver to the soap has lodged itslef in the pipe right ther prevneting free water fall into the unit
Posted on Feb 21, 2009
Water pouring out of the detergent drawer
Remove the dispenser draw and pour water down the soap chute as much as you can to soften any soap causing the blockage. When the water level drops, add more water. After a while use a soft flexible rubber hose and run it down the chute up and down to remove caked soap. Once this has been achieved, run the machine on "Rinse & Spin" to clean out the drum.
Mar 19, 2014 | LG WM2101H Front Load Washer
Water is pouring from water dispenser onto the floor, unable to flow into machine even if drawer is removed. How do I fix this?
Dec 07, 2013 | LG WM1814CW Front Load Washer
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water leaks out the soap despendser not filling the washer
Sounds like you have a blockage on the soap drawer remove it check and clean. pour a kettle of water in here make sure it goes away.......
Jan 29, 2011 | Samsung WF328AAW Front Load Washer
Whirl Pool Duet Sport WFW8300SW00 leaks water from the detergent drawer after about 30 seconds of water running...please help!!
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirl pool 1400 has stopped working the
Them washer are what you call high efficiency washers.HE. They only use 1 gallon of water to wash them clothes. You go adding more than a teaspoon of soap and that washer is gonna have a cow. Over a period of time that soap gonna build upb50e111.jpg so much the washer is gonna just give-up the ghost. If you know you use the correct amount of soap there could be something in them pump.You need to remove the service panel41b08ad.jpg and take a looksee at that tech sheet and see what it say about them light flashing. While you at it you may as well remove that cap6349b09.jpg and clean out that filter. d081835.jpgThat might put yall back in business. That tech sheet will be in there by that white box which is the motor control unit. The other stuff that the tech sheet error chart might reveal is located on the topside.539a7ad.jpg Good luck on dat repair mon ami.
Jun 06, 2010 | Washing Machines
Water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Water is pouring out of the soap dispenser onto the floor. how to resolve this problem?
sounds like the dipencer hose came loose.
Unplug & remove screws along top of washer in back.Lift up & remove. You should be able to access issue from there
Mar 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
106 people viewed this question
Dan Webster
Dan Webster
Sal De
