Find the water drain hole/pipe and clean it thoroughly with a pipe cleaner or other softish flexible rod. That should allow the water to drain away. Make sure back of the unit is clear and clean so water drains and evaporates off properly.
Setting should be midrange. If the freezer is frosting on the back panel you have a defrost problem. The coils will be iced over and the unit will slow down on it's cooling. If there is frost you will need to deice the coils by removing the frezzer back wall panel and use a hair dryer to melt all of the ice. The problem causer of all this will be either the defrost timer, defrost t-stat or defrost heater. Good luck.
Hello there: first make sure that the back of the unit is clear of any dirt or obstructions also make sure that the food is not stacked up so high that the air cannot circulate also you may want to check the temperature setting if the unit does not respond to a lower setting your refrigerant level may be low or than you will have to have the temperature controle thermistor serviced or replaced
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
This more than likely is because your evap.coil is frosted up do to a part failure with the defrost system. Look at the freezer back panel is there alot of frost growing all over it this is the number one sign. Either way take the back panel off and make a visual check. If there is alot of frost first get a multimeter and set it on Ohms with alert chime meaning you get continuity. First check the defrost heat if you get the chime sound from the meter or NOT a infinite number of Ohms then its good. Then look for the round shaped part hooked to the evap and in series to the heater this is the bimetal (while its good and cold) cut wires to it and strip ends and check for continuinty there also if so, it's good but must be frozen cold to get continuity wire nut it back after check if good. If those parts check out then your mechanical defrost timer is bad or adaptive defrost board is bad it would be either one depending on this model of fridge you have. Hope I helped.
