Question about Xerox WorkCentre M-24 Color Copier
NEED TO CHANGE THE TRANSFER BELT & CLEANER XEROX M24
IS THERE ANYONE CLOSE TO FAYETTEVILLE, ARKANSAS TO REPLACE THE TRANSFER BELT & CLEANER
    President:
  • 2,072 Answers
Total Document Solutions 2515 N. Shiloh Drive Fayetteville AR Y (479) 575-0770
Posted on Feb 20, 2009
Where is the transferr belt cleaner on a xerox workcentre m24
On the right side in the center of machine there is a small door you have to open that door and there will be the transfer belt there is also a handle to take it out you have to grab that handle and take it out slowly you will see the cleaning blade and assembly on the left side
Jan 23, 2013 | Xerox Workcentre M24 Color Copier
Need to replace transfer belt cleaner and 2nd bias transfer roll
Both are probably still good but the HFSI (High Frequency Service Item) counter needs to be reset. Unless something has changed with them that has to be done with the service laptop hooked to machine with a serial cable and using M24 diagnostics.
Jun 20, 2012 | Xerox WorkCentre M-24 Color Copier
Hie,am looking for a xerox M24 transfer belt at a cheaper price.Can you please help.Peter
One of the best prices I have seen and they have the best aftermarket support for Xerox.
http://www.partsdrop.com/belt-64k91451-xerox-style-dc3535-p-1782.html
Good Luck with your Xerox and Thank You for using Fixya.
Jan 11, 2011 | Xerox WorkCentre M-24 Color Copier
How to replace the cleaning product of belt transfer (m24)? Thank you for your answer
1. Remove IBT Belt Assembly (REP 9.15).
2. Remove IBT Cleaner Assembly (REP 9.16).
3. Remove Stand Plate (Figure 1).
a. Remove screw (2).
b. Remove Stand Plate in direction of arrow. Stand Plate will be installed in new location
in step 7.
Jun 26, 2010 | Xerox WorkCentre M-24 Color Copier
Change belt cleaner?
You have to move or remove the finisher, depending what finisher you have.
Open the door on the right side of the machine . It is about 4 inches high and 14 inches wide.
Open the front cover and move the black bar to the down position as if you were replacing a drum.
Then on the right side, you slide the transfer unit out about 4 or so inches. On the front of that unit there are 2 torx screws held together with a black plastic strip. Remove those 2 screws, remove and replace the cleaner.
Dec 31, 2009 | Xerox WorkCentre Pro C2636 Color Copier
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
My printer is saying it a fault has occurred and only allows me to access the Scan,menu but the photocopy is deactivated
Have you checked the machine status, then checked the supplies? One of your drums may just need replaced. Of the fuser life has reached its end, the transfer belt or cleaner may have reached end of life. That is the most likely reason you can scan and not copy.
May 18, 2009 | Xerox WorkCentre M24 All-In-One Laser...
Our xerox m24 workcentre needs a new belt cleaner
Yeah, you do. Sadly that is only on a Xerox rep laptop.
The diagnostics in that machine are not in the processor but accessed via laptop.
Instead of calling Xerox, you can look up a dealer in your area. They would do it and if you have no maintenance agreement they will do it for much much cheaper, what city to you live in? Let me know and I will send you the names of dealers in your area.
E-mail me at rak458@aol.com dont want you putting your city name on here. I will look them up and send you the info on dealer service in your area.
Feb 12, 2009 | Xerox WorkCentre M-24 Color Copier
Xerox Docucolor 2240 - how to change fusers & xfer belt cleaner?
I am not familiar with that particular model Xerox but generally speaking Xerox maintenance is more difficult that say your average HP, Lexmark, etc. I would call a service professional if I were you
Jan 20, 2009 | Xerox DocuColor 1632 Laser Printer
Xerox WorkCentre M-24 Color Copier Logo
2,003 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
