Question about Miele Novotronic T1515A Electric Dryer
Miele T1515 Elec Dryer Low Heat Problem
I own a Miele Novotronic T1515 electric dryer. We bought this as a set with our Miele washer but it never seemed to dry well. Had it serviced a long time ago under warranty and nothing checked out as defective. The dryer doesn't seem to get hot enough. Recently, as a test, we allowed the dryer to vent into our basement to dry three bath towels. I set the dry to 'cottons-extra dry and it took over an hour to dry. The vent discharge flowed well but was barely warm. I am not an appliance repair person but have repaired my own washers and dryers in the past. I can read wiring diagrams and have electrical testing equipment. I double checked the electrical voltage at the plug/receptacle and it checked fine (240/1/60). I understand that the dryer probable has thermostats and moisture sensors along with the heating element but have no idea how to check them. Is is simply a matter of swapping out a thermostat? Are there publications out there that may give me some guidence? Thx
3 Suggested Answers
  • 177 Answers
SOURCE: How do you remove the top of the Miele T1515
hi,
on each side of the lid at the front there is a plastic white cover. remove this with your fingers or a small knife. then using a T20 screw driver unscrew each screw a few turns and then push the screw heads in with your finger. do not unscrew the screws too far or remove them.
last push the lid back a few inches and it will lift off. once off you will see the locking clips that you just unscrewed which hold the lid down. when re-fitting the lid do the reverse and just tighten up the screws.
Posted on Apr 25, 2010
  • 2468 Answers
SOURCE: Miele Novotronic T230C Electric Dryer Dryer is
first check for 240 volts input on the unit if its electrically heated if you have no heat at all,then if you have some heat but it cycles on and off heat wise and the heat isn't as high as it should be,it can be the high-limit thermostat,the cycling thermostat both on the element housing,or it can also be a thermistor sensor on the blower housing if it only acts up on certain settings,you can bypass the 2 components on the element by jumping the wires on the components carefully together temporarily to see if this helps the heating cycle,but not the thermistor,as this is a resistance sensor
Posted on Oct 05, 2010
Tumble dryer does not heat up during cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 07, 2011 | Miele Novotronic T230C Electric Dryer
Does not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 16, 2011 | Miele Novotronic T1520 Electric Dryer
My miele novotronic t230c is not generating heat but work fine in all other areas. can you advise me please
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 21, 2010 | Miele Novotronic T230C Electric Dryer
I dont have manual for miele T5213 so cant tell - should heat button be pressed in for low temp. Doesn't seen to have time difference when drying towels
hi i have a miele t5213 dryer it was ok yesterday but today it is
not getting hot can you help also i dint have a manual for this
machine i lost it during moving house
regards jeff
Sep 19, 2010 | Miele Novotronic T1570C Electric Dryer
Miele T230C no water being extracted at all... no heat ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 18, 2010 | Miele Novotronic T230C Electric Dryer
Miele T1515 - has started to make my laundry room feel like a sauna - why?
check the exhaust hose. it sounds like it has separated from the outlet and is spilling the hot exhaust into the room rather than through the vent outside
Sep 17, 2010 | Miele Novotronic T1515A Electric Dryer
Miele T1515 electric dryer - overheats and laundry room feels like a sauna. What can I do about it?
is your dryer vented to the outside? Check the exhaust vent to be sure it is still attached to the duct and not plugged with lint
Sep 17, 2010 | Miele Dryers
How do you remove the top of the Miele T1515 vented dryer?
hi,
Apr 12, 2010 | Miele Novotronic T220 Electric Dryer
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Jun 26, 2009 | Miele Novotronic T230C Electric Dryer
Miele Novotronic T1515A Electric Dryer Logo
485 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
