Question about LG Prada KE850 Cellular Phone
Touch screen my lg prada touchscreen works when the sim card is disconected although not all numbers , but when i insert the sim card only number 5 works please help me
  • jameschege Feb 26, 2009
    no i already knew that how do i remove the screen to check the contacts
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The touchscreen of an LG Prada operates on capacitance effect. Your described problem could be caused if you have changed the face cover and or the SIM card is causing a warping of the contact board. Either way you would need to seek the services of a qualified person or LG Service Center. Particular attention would be needed on either the conductive coated substrates or the flex ribbon that provides connection to the main printed circuit board of the LG.
Good luck and thank you for using FixYa.
Posted on Feb 20, 2009
    Sergeant:
  • 326 Answers
Insert another sim and check out.or check out your sim with another device at a dealers shop.if its sim problem get it replaced if the devbice is faulty its necessary to open and check out the internal circuit of the device for making it proper.
    Sergeant:
  • 250 Answers
The simcard will be locked at particular settings.go to menu and then check out the settings and disable all the locks.
    Genius:
  • 1,550 Answers
It is hardware problem .
You need to remove your phone and check the contacts are proper between the screen and on board .
  • SAM ANDERSON Feb 27, 2009
    You get the information for disassemble from the link below
    Click this link to direct to disassemble of lg prada
    In that after 4th step check the continuity of circuit also check every thing is properly soldered .
    Also use multimeter to check the continuity of circuit.
    Hope this helps .
    For further help feel free to ask .
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Tip
LG KE850 Prada Unlock Code
Does your LG KE850 Prada work only with your current service provider or, when you insert a SIM card from another network, do you see any of the following messages?
  • Enter Subsidy Code
  • Enter Subsidy Password
  • Enter SIM Unlock Code (Simlock)
  • Contact Service Provider
  • Insert Correct SIM Card
  • Wrong SIM Card
  • Incorrect SIM Card
  • Phone Restricted
  • Can't Undo Restriction
  • Locked Return For Service
  • Enter Unlock Code
  • Enter Special Code
If so, your LG KE850 Prada is LOCKED and we can help you remove this lock on your LG KE850 Prada in a few simple steps, allowing you to use your phone on any GSM wireless network anywhere in the world.
You will not have to mail in your LG KE850 Prada. No Hardware or Software required. No technical knowledge required at all. Simply provide us your LG KE850 Prada’s IMEI number and we do all the rest.
Three Simple Steps
  1. Simply provide us your LG KE850 Prada’s IMEI (which can be found by typing *#06# into your phone), during check out.
  2. After order placement, the Unlock CODES together with easy to follow instructions guides will be sent to your email address within the time frame given.
  3. Follow the unlocking instructions provided by
    Reasons to remote unlock your cell phone
    • Save a fortune abroad, by using cheap local SIM Cards rather than expensive roaming tariffs.
    • As usually subsidize the cost of the phone, by unlocking it you are increasing the resale value of your LG KE850 Prada by up to 300%.
    • Use your work and personal SIM Card in your unlocked LG KE850 Prada - no need to carry two phones again.
    • Get the best value tariffs by swapping SIM Cards to take advantage of the latest offers.
    • You never send your phone to anybody.
    • Fast and easy. You receive the instructions within hours; unlocking itself takes 1-3 minutes.
    • No opening your LG KE850 Prada and risk of damage to your device.
    • Very easy, no technical experience necessary.
    • No complicated software or hardware just enters Unlock CODE, and your LG KE850 Prada is PERMANENTLY unlocked.
    • Is safe and does not void cell phone's warranty.
    • Unlocking is a one-time event. It works for the life of your LG KE850 Prada.
    Warranty
    All our Unlock CODES are 100% genuine and guaranteed, if for any reason your unlock codes are not found in our database then we will issue a full refund.
Instructions Unlocking Instructions for LG KE850 Prada
How to insert the Unlock CODE into your LG KE850 Prada
  1. Insert a not accepted SIM Card and turn ON your LG KE850 Prada.
  2. Your LG KE850 Prada will display "phone restricted".
  3. Select Cancel
  4. Your LG KE850 Prada will display "phone restriction code".
  5. Enter the Unlock CODE you received from UnlockallCellular.com
  6. Select OK
  7. Your LG KE850 Prada is now unlocked!
on Apr 07, 2010 | Cell Phones
How do you enter the unlocking code in the LG Prada?
you dont ...you let a certified technician do this to prevent damage to the pos
Dec 02, 2010 | LG Prada KE850 Cellular Phone
I have a lg viewty touch screen phone, the touch screen doesnt work but i can still see the screen perfectly, do i buy a whole screen or just a lcd part??
You just need to buy a replace touchscreen. You can replace it. They run about 15 dollars from ebay and are pretty straight forward. Here is a link on how to replace the touchscreen on the Ku990.
How to replace touchscreen on LG Viewty KU990
Jun 15, 2009 | LG Prada KE850 Cellular Phone
I have an lg prada ke850 touch screen phone and I was trying to set in a security code but instead I just locked my phone. Can you please help? I don't know how to unlock it!!!!!
This is a small tutorial on how to hard reset the lg prada on request for forgotten security code. Turn the prada on without a simcard and wait for the insert sim screen. On the touch screen hit call, after enter this code 2945#*#. and you will see a menu pop up headed "Engineering menu". scroll down to factory reset hit that and wait for it to reboot.
Best Regards
May 14, 2009 | LG Prada KE850
LG Prada security code
Best Regards
Dec 25, 2008 | LG Prada KE850 Cellular Phone
Lg prada
turn handset off and take battery out and sim card then put them back in and turn mobile back on then do a master reset under the settings section.
Oct 05, 2008 | LG Prada KE850 Cellular Phone
Sim card rejected
When i open my nokia 5800 it says sim card rejected what can i do helpppppppppppp
Sep 07, 2008 | LG Prada KE850 Cellular Phone
LG Prada - can't detect my SIM
Try the SIM in another phone. SIM cards go bad.
If it doesnt work in the other phone it will have to be replaced. I
THis can also be caused if you set up a PIN code and it was entered in wrong too many times and you did not use the right PUK code to unlock it. THis will permanently damage a SIM card.
f it does work in another phone then your phone is no longer able to read SIM cards. Check with the manufacturer for warranty info.
Feb 05, 2008 | LG Prada KE850 Cellular Phone
LG PRADA PHONE TOUCHSCREEN NOT RESPONDING
Ok after a bit of research I understand that the Lg Prada phone uses a Capacitive touchscreen technology. Wiki this and you will find that the plastic strip attached to the underneath of the front cover of the phone (with its circuit ribbon that connects to the main circuit board of the phone) has a sticky substance holding it air tight to the underside of the front cover. This sticky substance is Indium Tin Oxide (ITO) and conducts a continuous electrical current accross to the sensor. So if you have bought a new cover from ebay etc like I have and replaced the new cover with the old scratched one, you need to get yourself some ITO sputtered onto the screen to make its capacitive touchscreen technology work again.... hope this is a more technical answer than some of the idiots that post unhelpful solutions to questions(solution 1!).
Nov 08, 2007 | LG Prada KE850 Cellular Phone
LG Prada KE850 Cellular Phone Logo
26 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
